Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Repoduction 911 R / ST /RSR parts - lwt seat brackets
    Sep 2008
    Auckland , New Zealand
    Well i have had a few people chasing me for these so i have put it to the top of the list . The prototype is being produced ready for next week , this will be sent to Gib for checking / mounting and from there if we are happy will go into production. there will be two versions made (3mm and 5mm ) so if you are of the larger sizing (compared to the drivers of the 70's we all are ) the 5mm will take the weight better.
    So expressions of interest please and as always we will be working to produce these as cheaply as possible for everyone .
    as a side note , if anyone has a genuine bar not installed that would provide some more photos it will help get these accurate.
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Looking really good John. One of the main problems I've found with the lightweight cross bars is that they tend to mount the seat to high.
    If using original Recaro 4 hole brackets as pictured below, you want to be careful your design means that you can use the top hole so you
    have the option of the seat sitting as low as possible. The original bracket and copies I have seen will not let you use that top hole.
    Hope that's of some help.
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Sep 2008
    Thanks mike i have advised the engineer to keep the capture nut low to the body of the bar
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    John - cool! Keep us posted.
    Mike - school me. I thought the brackets have only three adjustment holes.
    EDIT: Mike - it's me again. Bob. I assume those are originals and not repros. Si or no?
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    John,
    Glad to see you are making these. Count me in for a set.
    Take care,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    I'm in too.
    Thanks!
    Quote Originally Posted by bob tilton View Post
    Hi Bob, the original brackets for the sports Recaro buckets have 4 holes, and Si the ones in the picture
    are an original set that have been re-finished.
    cheers, Mike
    Member#1664
    Aug 2007
    Phila Pa. area
    Seat Supports
    I am interested.
    Mike Curnow
    Mike
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    Quote Originally Posted by Mike_Moore View Post
    I agree with Mike on this. It has to do with the shape of the bracket and the position of the welded nut.
    Also I'm not sure what the right way to mount these crossbars is. The problem with the top hole of the slider is only there when mounting them what I believe is upside down. If you flip em upside down the nut for mounting is in a lower position, but I'm not sure yet if there is enough clearance in the chassis of the car to mount it that way. (I've added some pictures of the 2 positions)
    If you look at the original recaro tilt frame, the rear mounting point for the s;lider are lower than the fronts, giving the seat a more leaned back position. This way the seat is more confortable for most people and gives more head room.
    (I can't wait to put my lollipops in the Hotrod )
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Apr 2005
    Oregon
    Quote Originally Posted by varunan123 View Post
    These photos will hopefully help display the fit issue-the only way to gain real height is to cut down or tilt.
    raj
    I'm pretty sure I flipped the rear cross bars upside down for headroom and seat angle here.
    Mark
  1. FS: LWT R/ST/RSR seat brackets - new run this week
    By advtracing in forum For Sale: 911 Parts
    Last Post: 06-01-2016, 04:12 PM
  2. What seat brackets are these?
    By Todsimpson in forum General Info
    Last Post: 11-30-2013, 11:32 AM
  3. Repoduction 911 R / ST /RSR parts - lwt seat legs (retofit)
    Last Post: 12-20-2011, 08:23 PM
  4. Fs: 73 Inertia Reel Seat Belts, Sport Seat Brackets
    By rick2 in forum For Sale: 911 Parts
    Last Post: 01-07-2011, 10:29 PM
  5. FS: Early OEM Seat Brackets
    By jhora in forum For Sale: 911 Parts
    Last Post: 02-02-2008, 07:43 AM
