Results 1 to 9 of 9
Thread: Remove headlight switch
    Jul 2010
    Lisboa, Portugal
    Hi.
    I want to replace the old dash vinyl for a new one black basketweave and for so I need to remove the headlight switch in my 1970 T Targa
    How can I remove the light switch? Tried do turn it conterclockwise but I was afraid of broken it.
    Thank you.
    José
    Uploaded with ImageShack.us
    José Albuquerque
    1970 911 2.2 T Targa
    Junior Member
    Aug 2011
    Ireland.
    Jose`, the switch knob is secured with a 3mm or 4mm grub screw, on the underside of the knob, which prevents it from unscrewing when the dash lighting brightness is being adjusted. This grub screw must be loosened with a small plain screwdriver, before removing the knob.
    As a coincidence, we also have a `Targa` but it is a 1969 `S`. Best wishes, Paul Martin.
    Jul 2010
    Lisboa, Portugal
    Thanks Paul. I'll look for that screw.
    José Albuquerque
    Jul 2010
    Lisboa, Portugal
    As for the hazard switch, it's only pull both ends and it will separate, right?
    José Albuquerque
    The hazard knob unscrews counterclockwise
    Jul 2010
    Lisboa, Portugal
    Are you sure about it? I couldn't unscrew it... Should I unscrew the red button or the bezel around it?
    I had no problem with the light switch.
    Thank you!
    José Albuquerque
    Jul 2010
    Lisboa, Portugal
    I found this thread with all my answers:
    http://www.early911sregistry.org/for...-hazard-switch
    Thank you
    José Albuquerque
    On a 73 you unplug the hazard switch from the rear and then carefully push out, it is held in by pressure clips. I don't know if it is the same on a 70.
    I think David nailed it, I was talking about my 68 which is different.
  1. remove indicator switch
    By albuquerque in forum Technical Info
    Last Post: 01-11-2013, 09:18 AM
  2. Headlight switch
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 10-18-2012, 04:31 PM
  3. FS: 78-88 headlight switch
    By dallaseurocars in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-03-2010, 11:53 AM
  4. FS: 65-73 Headlight Switch
    By ulrichd in forum For Sale: 911 Parts
    Last Post: 02-02-2008, 03:02 PM
  5. How to remove headlight assembly...
    By VinnyC in forum Technical Info
    Last Post: 04-11-2006, 10:36 AM
