Results 1 to 7 of 7
Thread: 1971: where to do stone guard under enamel
    Junior Member
    Oct 2010
    South of Germany
    Red face 1971: where to do stone guard under enamel
    Hello together
    This is my first post in this forum, so let me say hello to everybody and let me give a short introduction:
    Living in the south of germany, I bought and restored my first early 911 thirty years ago. 15 years later a delivery truck crashed my ´69 Porsche and it was completely destroyed. Never forgot an early 911 and then, three years ago, I found a very complete 2.2S. Again a lot of work e.g. suspension, chassis and interior, but hopefully the car will run again next year.
    Currently I am nearly finished with a complete new painting of my 2.2 1971 (signal orange- original colour ). But there is still one important question and with respect to my painting facility I need a fast answer . As there are a lot of experts on these things, I hope someone can give me a quick response.
    Does somebody know in which areas should be done a stone guard cover under the new painting. I would like to do this in an original look like the car left the factory.
    1. lower area of doorsills (area under deco strip /aluminum covers)?
    2. lower outside area of front or rear bumpers?
    3. fenders/ inner lip at the wheel opening area?
    4. lower part of the rear center panel?
    pics would be helpful
    Thank´s for your help.
    regards
    Werner
    Thumbs up
    Welcome to the board Werner..........
    I trust help for your questions will come soon........
    Oct 2010
    Camarillo, Ca
    1. lower area of doorsills (area under deco strip /aluminum covers)? No
    2. lower outside area of front or rear bumpers? Not outside but inside
    3. fenders/ inner lip at the wheel opening area? Yes
    4. lower part of the rear center panel? No
    Lower outer rocker panels- yes
    Love to see your car if you would not mind sharing.
    1970 911E coupe
    1979 930 Coupe US
    1978 930 Coupe Euro
    1980 911SC sport
    1969 911S Coupe Euro
    1971 914-4 1.7
    I think by deco trim he may have been referring to the aluminum trim over the outer rockers, under which, as stated above, there should be stone guard finish.
    Oct 2010
    Camarillo, Ca
    Dave, Yes that would be correct, sounds like that is what Werner was referring to, not the alu sill plates that I understood them to be...
    Ron
    1970 911E coupe
    1979 930 Coupe US
    1978 930 Coupe Euro
    1980 911SC sport
    1971 914-4 1.7
    Junior Member
    Oct 2010
    South of Germany
    Hello Ron hello David
    thank´s for your help. Everything is clear now and we can go ahead with the painting.
    As soon as the car will be finished I will add some pictures.
    regards
    Werner
    Check this thread out as well. I was researching recently because I'm about the put fresh undercoating on my '72 prior to sending out to paint. Hopefully this helps.
    http://www.early911sregistry.org/for...oating-on-a-72
    - Josh
    - '72 911t
    - '81 euro SC
  1. Wurth SKS stone guard grey discontinued?
    Last Post: 03-29-2014, 01:52 PM
  2. Painting a 73T. Stone Guard Question
    By ddinham in forum Technical Info
    Last Post: 12-04-2013, 04:41 PM
  3. WTB: Early S Oil Cooler Stone Guard
    Last Post: 02-01-2013, 05:42 PM
  4. Replies: 1
    Last Post: 09-20-2011, 08:38 PM
  5. wurth sks stone guard
    Last Post: 03-17-2007, 03:05 PM
