Results 1 to 2 of 2
Thread: Wicked 70mm Crank
    Nov 2002
    Fremont, CA
    Wicked 70mm Crank
    I made two of these, one of which is going in a customer's engine.
    I have decided to sell my other one.
    This is a super lightweight, 70.0mm-stroke, custom ground crankshaft made from a Standard/Standard Non-Counterweighted early 66mm Crank. It has also been fully cross-drilled and grooved on the center main bearing for racing applications.
    It runs standard main bearings for a 1965-1977 2.0/2.2/2.4/2.7/Euro 3.0/3.0 Turbo case.
    It uses GT3 Rod Bearings (Standard items) 996-103-121-81 $139 / set (Pelican) . Rod bearing diameter is 53mm as per 911SC/GT3.
    It has been custom ground to lengthen the stroke to 70.0mm (NOT 70.4mm). A 2.7 is 2672cc instead of 2687cc, a '2.4' is 2328cc instead of 2341cc...etc. See formula (bore in mm / 20)^2 * 3.1416 * 6 * (stroke=70.0mm / 10) = ___ cc
    Connecting Rod choices - standard 911SC 3.0L connecting rod for cheap, or GT3 Titanium Pankl Connecting Rods (all versions) drop on to this crank.
    It is much stronger than the standard 2.4/2.7 crankshaft, because the flyweights are thicker. OK to run to ~9000rpm, possibly lower depending on other component selection.
    Available at $1,500 shipped.
    Contact me at kindersport@gmail.com with questions or interest
    Thank you
    Scott
    scott kinder
    Registry #614
    Nov 2002
    Fremont, CA
    ttt..............for any new viewers?
    It might sound a little complicated, but, if you are building any six-bolt engine, 1965-1977, this is one fantastic choice for a crankshaft.
    Let me know if you have any questions?
    thanks,
    Scott
    Kindersport@gmail.com
    scott kinder
    Registry #614
  1. FS: folger track extensions 35/70mm
    By moito in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-21-2015, 04:34 PM
  2. FS: '68 std/std crank
    Last Post: 09-09-2010, 09:39 AM
  3. 2.7 911 crank
    By fosterboy in forum For Sale: 911 Parts
    Last Post: 06-14-2007, 01:41 PM
  4. $10,000 Crank?
    By rick2 in forum Off Topic
    Last Post: 09-05-2006, 06:42 AM
