Thread: Oil tank restoration
    I need to strip and clean the exterior of my oil tank.i have used paint remover so far.it seems to work ok.i would like to have it dipped in a tank,like at a radiator shop.does any body know if the oil tank is soldered together or brazed?a machine shop said they could tank it,bu only if it was brazed together.any help would be appreciated.any body know of a radiator shop in northern,va.
    Thanks david
    Oil tank is safe to dip at any radiator shop with a tank. Not soldered.
    Sherwood
    Thanks sherwood,off to the shop.
  1. Gas tank restoration
    By merbesfield in forum Technical Info
    Last Post: 12-29-2014, 01:22 PM
  2. Gas tank restoration
    By merbesfield in forum General Info
    Last Post: 11-06-2013, 06:17 PM
  3. Oil Tank Restoration
    By 50/50 in forum Technical Info
    Last Post: 04-24-2012, 02:32 AM
  4. Oil tank restoration help!!!
    By joseph battista in forum For Sale: 911 Parts
    Last Post: 08-02-2011, 08:49 PM
  5. Gas Tank Restoration
    By 69Sman in forum Technical Info
    Last Post: 04-25-2011, 08:03 PM
