Thread: help removing seats
    help removing seats
    I have a 73 911 that I need to remove the seats. Can you just slide them forward to get them off the track like a 356? Thanks in advance for the info. Tom
    Yes, on the 73 there might be an electrical connector for the seat belts(?) my experience is with a 71. these are not tilt base sport seats I am presuming. S
    They do not slide off the rails like a 356, you have to unbolt the sliders from the floor mounts by sliding the seat fore and aft to access the front and rear bolts. You then lift out the seats with the sliders on them.
    #1704 58cab's Avatar
    Nov 2002
    Mountain View, CA
    And you need a 17mm open end to remove the outer seat belt bolt.
  1. Removing muffler on 69 911- Help
    By al z in forum Technical Info
    Last Post: 09-19-2013, 03:41 AM
  2. Removing seatbelts, and recievers from stock seats
    By Martin A in forum Technical Info
    Last Post: 05-03-2009, 02:37 PM
  3. removing doors
    By ajwans in forum Technical Info
    Last Post: 03-03-2008, 02:37 PM
  4. removing speedometer - 73E
    By racemor in forum Technical Info
    Last Post: 03-03-2007, 06:19 AM
  5. Removing VIN Tag for painting?
    By bobmagyar in forum General Info
    Last Post: 01-13-2005, 08:03 PM
