Thread: MFI injector dimensions
    mad scientist
    Apr 2007
    Austin, TX
    I was wondering if someone could help me out with MFI injector dimensions. I have a project brewing and do not have an injector on the shelf to measure myself.
    What is the thread diameter and pitch?
    What is the thread depth?
    What is the diameter of the sealing washer?
    how long is the "injector nozzle" section below the threads?
    What is the diameter of the injector nozzle?
    What is the length of the injector body above the threads?
    What is the overall length?
    What is the thread diameter and pitch of the fuel line connection?
    Jamie
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
    Jan 2003
    UK
    Jamie - didn't know how accurate you wanted the measurements but here you go:
    What is the thread diameter and pitch? M12 x 1.5
    What is the thread depth? Approx 14mm
    What is the diameter of the sealing washer? M15.5 x M12
    how long is the "injector nozzle" section below the threads? Approx 14.5mm
    What is the diameter of the injector nozzle? 9.65mm
    What is the length of the injector body above the threads? Approx 27mm*
    What is the overall length? 67.2mm
    What is the thread diameter and pitch of the fuel line connection? M12 x 1.5
    * from the top of the threads to the top of the hexagonal portion
    Andy
    Early 911S Reg #753
    R Gruppe #105
    mad scientist
    Apr 2007
    Austin, TX
    Cheers Andy,
    Exactly what I was looking for. No need for more resolution than you provided.
    I have some old ones if you need any.
    Alan
    I assume you plan to modify something more common? I would assume pintle sizes and spring pressures are also going to be a factor but I haven't had any direct experience with the Porsche/Bosch MFI system but have had a bit to do with diesel systems and they look very similar so I suspect the principles are the same.
    I will probably need some injectors in the future so if you come up with something interesting, I'm sure there would interest here.
    cheers
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
  1. WTT: mfi injector lines
    By jc4me2 in forum Free, Trades, and Swaps
    Last Post: 03-26-2014, 10:07 AM
  2. FS MFI Injector Lines
    By jloucks388 in forum For Sale: 911 Parts
    Last Post: 01-05-2012, 02:29 PM
  3. WTB - MFI Injector(s)
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 10-15-2009, 07:48 AM
  4. MFI injector plugs?
    By Flat Six, inc. in forum Technical Info
    Last Post: 07-01-2009, 03:46 PM
  5. WANTED: injector for 69-73' MFI
    By erick72pors in forum For Sale: 911 Parts
    Last Post: 05-18-2009, 10:33 AM
