Thread: 118 driving light restoration question
    Has anyone tried to separate the glass lens from the metal reflector of a 118 driving light with good results? Seems like there must be a way. I just bought a nice used example that is almost perfect except for some rust on the reflector. I would like to send the reflector out to be rechromed. Any tips would be appreciated
    UPDATE: Empowered by the responses to the post I took a closer look and determined that I had the early rubber gasket version. Now its off to be "resilvered"
    Thanks Guys!
    Jul 2008
    South Florida
    For no worries (but a little cash) send them to a reputable shop that re-silvers lights.
    These two are some of the best, one in the USA, the other in England.
    http://www.stevesautorestorations.com/headlight.php
    http://www.vintage-headlamp-restoration.com/
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    The early type has a separate lens and reflector with a rubber sealing ring. The later type, that it seems you have, are sealed with a rock hard compound of some sorts. I have tried to separate a few of them with no luck. One example with a bad reflector, I cut away the reflector bit by bit with a saw to save the lens which was in good condition. Even that was quite difficult without cracking the lens. Maybe someone knows of a chemical that can dissolve or soften the sealing compound without damaging the reflector or lens?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
  1. Under bumper driving light/fog light help.
    By Ccamut in forum General Info
    Last Post: 08-09-2013, 08:08 AM
  2. Fog light vs driving light switch
    By TZombek in forum Technical Info
    Last Post: 10-17-2012, 06:55 AM
  3. Replies: 18
    Last Post: 10-28-2007, 06:53 PM
  4. Correct Driving light/Fog light information
    By rich roush in forum Technical Info
    Last Post: 09-19-2006, 05:21 PM
  5. Cibie question, fog or driving light?
    Last Post: 06-22-2006, 07:25 AM
