Where can you buy the 8mm/9mm white plastic plugs for the floor of the 911 think there are 12 in total all the ones that run down the middle of the tunnel
and the outside of the floor
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Did they use white plastic plugs in the 72?
My 69 had rubber plugs in the floor pan but only has the drains on the outside of the floor 6 in total, going into the cavity where the seat rail cavity is.
I think 69 and earlier cars didn't have the drains in the center tunnel.
If they are the same as mine I ended up getting VW beetle apron plugs, which are an exact match for what came out of the car.
If you need a photo or part number I can check on both when I get home next week.
Tony
I've been looking for these also Clyde.
The VW part # plugs run around the outside perimeter. They are black and the head is about the size of a nickle. Very soft thin rubber.
Please post what you find. I'm looking for a complete set of body plugs for my '72 as I put it back together.
- Josh
- '72 911t
- '81 euro SC
My 1970 has rubber plugs down the tunnel and I was able to get them from stoddard a few years back. I would have to dig to find the part number.
Jule
my 72 has black rubber plugs.
there is no listing in PET for a replacement.
however,
stoddard sells a superceded part 999-703-013-50 "rubber plug" @ $0.87.
this plug is listed as a fan shroud air duct plug, but is identical to the floor pan plug as far as i can tell.
IIRC,its what i used.
maybe purchase one to be sure, stoddards shipping costs are very reasonable for small items
bob moglia
'72 E sunroof coupe
Clyde, I have the part # at home. I'll get it ASAP. Order them from a VW dealer they are half the price.
I am looking for a source to purchase the one big rubber plug in the smuggaler box. Is this plug one that someone has a supplier for?
Thanks in advance
Curt
Curt Hammill
911S#2032
http://www.linkedin.com/pub/curt-hammill/38/347/849
1969 911E 2.5ss twinplug
http://www.911e.org/microsite.php?119200483
1997 993C2s
Audi 1983 groupB rally tq-sport
http://www.1-buc.de/site/content/2_news_1006.html
Hi Clyde,
Stoddard has a whole page/section of plastic body plugs in their catalog.
The center tunnel plugs are rubber...round button with center hole on outside and conical tip inside...slightly bigger but same shape as the VW rear apron plugs.
Rumor has it that Terry Morehouse of internatinal Mercantile was making these tunnel plugs.
Now to start an argument.....one day at EASY Jim and I crawled around looking at 911 pans.....Karmanns had the plugs...Porsche/Reuter had no plugs or holes!
My '69 Karmann 911 and 912 both have those plugs.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
