Results 1 to 10 of 12
Thread: whats it worth? wiring harness
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    in dismantling this car, I have been extra careful with all of the wires and connectors... its becoming a PITA.
    so what im deciding on is if it is worth the extra time or not. what is the going rate for a full wiring harness both brand new and used from a parts car?
    please do not start responding with offers, i dont want this to be perceived or interpreted as an auction. If anyone knows of the going rate or price range that would be great. i can then assess if its worth the extra effort to save it or if i should just start cutting in order to make quicker work of this car.
    Harry Hoffman
    356 Registry Member #36691
    Harry, please remind us what this harness goes to....?
    Feb 2003
    sorry, 67 912. should be the same wiring as a 911 from my understanding.
    Harry Hoffman
    That harness may well save someones day - perhaps even yours, so its worth taking the extra time to not hack it up. =)
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Feb 2003
    good call Dave. I'll continue down the ocd path
    Harry Hoffman
    Junior Member
    Nov 2010
    Santa Rosa,Ca.
    Harry
    I spent the better part of an afternoon to remove a complete harness all 21 feet. I know you can do it.
    Chuck
    Harry,
    It's only worth anything if it's close to perfect. That means no burned wires, hacked wiring, paint on wires etc. $200 or so would be a reasonable price. A new harness is like $3,000.
    Feb 2003
    question.. how do you disconnect the headlight connector to pull the wires through the tubes in the headlight buckets that lead to the chasis? the connectors dont fit down the tube..
    Harry Hoffman
    Depends on which style you have, could be bullet connectors that just unplug, or could be locking tang female connectors that you use a very narrow tip flat screwdriver to push in and push back locking tang. Post a picture and I'll tell you which style you have.
    Quote Originally Posted by hoffman912 View Post
    Harry,
    First, take out a small hammer, hold it in your right hand, and smack a fingertip of your left hand with it. This will approximate what it feels like when you remove those headlight connectors and pinch your finger in the clamp, so you can tell you're doing it correctly! (That's what I always do)
    Next: take a pair of water pump pliers and grasp the brass terminal-- this looks like a right angle-- and squeeze it toward the side that the bulb goes into. This should allow the wire to release.
    Save those connectors, they can be cleaned with a little salt and vinegar soak followed by fresh water, then sprayed with WD40 to displace the water.
    This should allow you to pull, gently, the harness out of the headlight tube. I would not be above putting copious dishwashing liquid down the tube as a lubricant.
  1. Whats a 902/16 gearbox worth?
    By Cornpanzer in forum General Info
    Last Post: 01-05-2012, 05:41 PM
  2. Whats it worth
    By donzi in forum For Sale: 911 Parts
    Last Post: 07-09-2008, 02:21 PM
  3. Whats it worth
    By donzi in forum General Info
    Last Post: 07-08-2008, 05:18 PM
  4. whats my car worth?
    By zmayne in forum General Info
    Last Post: 05-29-2004, 03:59 AM
  5. Another whats my car worth-71 S Targa
    By ccandgc in forum General Info
    Last Post: 01-20-2004, 09:11 AM
