Thread: Source for ALUMINUM oil cooler fittings to repair early S cooler??
    Aug 2003
    Van Nuys, Ca
    Tried BAT in florida, tried the usual sources (Earl's, TRS, Orme bros) and no luck. Looking for the male threaded fitting that can be modified/ welded in place of the stripped/ damaged ones on a cooler
    another option would be if someone has a unrepairable early cooler with good threaded fittings
    HELP!
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    We could probably make one for you given some time. What year cooler male fittings do you need?
    I have coolers from 69-71, 72 and the 73 version here.
    HTH
    Alan
    Aug 2003
    Van Nuys, Ca
    Thank you Alan
    we found a local machinist to make one for the immediate need. It would have been for a 69-71
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    Hi Dave,
    I have a few of the aluminum M26x1.5 60* cone fittings on hand. Let me know if you still need them...
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Aug 2003
    Van Nuys, Ca
    Thank you Brad
    the long drive was worth it !
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
  1. Replies: 10
    Last Post: 09-12-2013, 01:53 PM
  2. Replies: 8
    Last Post: 09-18-2012, 08:28 PM
  3. WTB: Aluminum oil cooler for fender
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 05-10-2009, 07:49 AM
  4. Oil tank/cooler fittings question
    By gtgroupe3 in forum Technical Info
    Last Post: 07-24-2008, 09:24 PM
  5. 911 S Oil Cooler Repair
    By greens in forum Technical Info
    Last Post: 01-05-2006, 03:29 PM
