Results 1 to 10 of 18
Thread: Solex PI 40 rebuild
    Oct 2010
    Denmark
    Solex PI 40 rebuild
    Here some picture from my solex rebuild.
    Carbs drilled out to 42 mm
    Venturi new 34mm
    New butterfly 42 mm
    Taller stack for more mid end tourge
    Trottelshaft axel resealed with new seal PTFE based elastomeric seal. They are also used in some Webers
    New banjo in stainless steel
    emulision tubes re-enginered
    carbs is build to match my 1965 2.0 l 190 hk engine
    thanks for looking
    Lars
    Sep 2006
    La Quinta
    Beautiful!!!!!
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Lovely! Who did the work? Duel or other?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi Lars, I popped over to see Chris last weekend (we're local), he's making some lovely parts. He's almost re-made everything bar the carb bodies and jet pack carrier, top work. It's nice to know we won't be running out of spares anytime soon.
    Chris is on here, I'm sure he'll chime in.
    Oct 2010
    Denmark
    Yes chris have done a super work with a lot of new spareparts for the Solex Pi 40 and he have done a super job on my carbs as well.
    Oct 2010
    Denmark
    New pictures...Name:  sparepart.jpg
Size:  221.4 KBName:  sparepart1.jpg
Size:  218.9 KBName:  solex fitted 1.jpg
Size:  262.7 KBName:  solex fitted.jpg
Size:  232.8 KB rg.lars
    Sep 2006
    La Quinta
    Nice!
    Is he remaking the floats?
    Registry #983
    R Gruppe #741
    Oct 2010
    Denmark
    Hi John
    I have not heard of any who makes new floats, but you can dry the original out , so they weigh 7 grams, and if you return the gasoline to the tank, you can run without the float, it all depens thoug if yoy run stock engine 130 hk with one elect. bendix pump and one mecanical pierburg pump, or you go the race set up with 3 elect. pump.
    rg.lars
    Aug 2006
    Sonoma, CA
    If one runs without floats, try filling the float chamber with fuel cell material. This dampens the sloshing of fuel in the chambers when driving hard. This is an old Baja trick that really improves driveability.
    johnt
    Sep 2006
    La Quinta
    Thanks lars...I need to keep mine looking stock.
    Registry #983
    R Gruppe #741
  1. Replies: 1
    Last Post: 01-09-2014, 12:17 PM
  2. First 1965 solex Pi 40 drive after rebuild
    By lars1965 in forum General Info
    Last Post: 02-24-2012, 02:18 PM
  3. Solex Fuel pump rebuild - where to get kit?
    By kenikh in forum Technical Info
    Last Post: 08-09-2008, 05:22 PM
  4. Who to rebuild Solex carburetors?
    By YTNUKLR in forum Technical Info
    Last Post: 11-27-2006, 06:56 AM
