Results 1 to 10 of 13
Thread: sway bar question
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    sway bar question
    ok, what kind of sway bar bracket is this? it doesnt look like any i have seen. is it home made? aftermarket? early factory? Is it OK or is it suspect?
    my car doesnt have a sway bar, so this is one of the few things i wouldnt mind keeping from the parts car, but want to know what it is before i decide to put it on.
    Harry Hoffman
    356 Registry Member #36691
    It's an adjustable lever for the sway bar. They were made in a few different styles by a few aftermarket companies to help stiffen up the 15mm bar.
    They work okay, but they increase the tendency to "POP" the drop rods, which are already prone to breakage.
    I installed a set on my father's car at the softest setting with a set of Weltmeister adjustable drop links and they seem to work fairly well. The holes and hardware are usually SAE, but I just re-drill the drop link holes to metric size for ease of use. I leave the clamp part American because you mess with it so rarely.
    I'd say they're worth about $150 bucks for the pair in clean, cad-plated condition. As in the photos ... $75-100, tops.
    -Marco
    TLG Auto: Website
    Feb 2003
    what size bar do you have on your dads?
    I take it the farthest hole form the bar is the softest and the closest is the stiffest?
    Harry Hoffman
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by hoffman912 View Post
    Yes, that is correct. It is easy to intuit the function from the geometry involved. The shorter the lever arm (i.e.--the closer the droplink connects to the axis of rotation of the bar), the less wheel travel is necessary to impart the same degree of rotation on the bar, and the faster the load will be transferred to the other side of the car.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Non-factory 19 or 20mm.
    -Marco
    TLG Auto: Website
    Nov 2010
    North Carolina
    Harry, you can measure the diameter of the bar with a pair of calipers. If it's a 19, you would also have to add a rear sway bar.
    Feb 2003
    I cannot get these darn things off the bar :grr: the allen heads are stripped and i cant even get them off with vice grips. tons of liquid wrench used too..
    what do you suggest next? Torch?
    Harry Hoffman
    Harry, when disassembling old rusty hulks an oxy-acetylene torch is pretty much a necessity. Bolts heated to a cherry red almost always unscrew. Your other best friend is a cut-off wheel tool, oh, and an impact driver.
    Feb 2003
    jesus.. this thing (67 912) had a 19mm sway bar on the front :O (no sway bar in the back of course). the rear mounts for the front end were not connected to anything (rusted out holes were where it should have mounted).
    i never actually had a chance to drive the car (the throttle linkage folded under the pedal when i tried to take it out of the driveway for a test drive), but i can only guess the handling would be interesting.
    so.. how desirable is a 19mm bar? i dont see them discussed too much so not sure if its overkill for early 11s, or desirable or what. how do i tell if its factory or aftermarket?
    Harry Hoffman
    A 19? Are you sure it's not an 18?
    If its a 19 it's probably a Weltmeister.
    -Marco
    TLG Auto: Website
  1. Sway Bar Mounting Question
    Last Post: 12-10-2012, 11:31 PM
  2. Quick Front Sway Bar Bushing Question
    By Haasman in forum Technical Info
    Last Post: 10-27-2012, 06:30 PM
  3. Front sway bar question for a 68
    By Rolls 912 in forum Technical Info
    Last Post: 01-23-2012, 03:14 AM
  4. Sway bar question
    By joetiii in forum Technical Info
    Last Post: 07-28-2011, 02:01 PM
  5. Rear Sway Bar Drop Link Question -
    By zcat3 in forum Technical Info
    Last Post: 09-28-2004, 11:00 AM
