Results 1 to 10 of 18
Thread: Tire recommendation
    Tire recommendation
    Just bought a set of Fuchs 7x15s and need to put new rubber on them. There are not many tires available anymore in 205/60-15 or 215/60-15. Does anybody have a tip / recommendation where to look and what to buy?
    Saw on TireRack that BF Goodrich (g-Force Sport) and Yokohama (AVS ES100) are the only brands still making Ultra High Summer Performance tires in these sizes. Anyone has experience with these tires on an early 911 Porsche? Wondering if other brands carrying 60-series tires are still available in Europe?
    Any tips / recommendations highly appreciated.
    Thx.
    Conny
    _____________________
    1973 911S Targa 2.4 MFI
    If you want ultra high performance..... I run Kumho V710 tires on my 7x15 Fuchs. 225/50 on all 4 corners.
    "Speed never killed anyone. Suddenly becoming stationary...that's what get's you."
    1973 Austin Mini
    1975 911S 3.2 "the blue goose"
    1973 911E sunroof 3.2
    Nov 2002
    Worshington State
    If you don't want extremely low clearance of 50s (beware rocks, branches, steep curb cuts, and pot holes) you may want to reconsider Dave's recommendation. However if you don't have any of these obstacles, the Kuhmos might be an excellent choice. I moved from 60s to 55s and live in the boon docks. Large branches and rocks which roll onto the road but the fear of gawd in me and regularly rub the S spoiler on steep curb cuts and an occasional unlucky racoon. I have the Yoko S Drives (ultra hi-po summer tires) and even though they are plenty sticky, have a bit of sidewall flex compared to my dearly departed SO3s. Am still getting used to their rebound coming out of the corners. That said the S Drives have a bit higher consumer and the top Tire Rack test results.
    Thanks for the recommendations. I'm trying to avoid going to 50-series tires since I like the original 60-series look (I know that the selection in the 50-series is a lot bigger). I currently run 205/60-15 Bridgestones on my 6x15s and am also experiencing more sidewall flex compared to the Yokohamas 008s, which I ran before.
    I heard that the BFGs have a pretty stiff sidewall - can anyone confirm?
    Thx. much
    Conny
    Tire recommendation
    Goodyear Eagle GT in 195 X 65 is my choice, photo shows it on my 7R rim. It is also a V-rated tire.
    Jan 2011
    DFW TX
    Seems like we've had this discussion before. I like the Kuhmo ASX in 205/60 VR15 or 195/65 but they are only $10 or so cheaper than Ed's Goodyears at Tire Rack. You definitely want a V rated tire.
    tire recommendations
    Magnus threw up this photo of his new tires. Yokohamas. They look like a nice profile.
    1973 Austin Mini
    Thanks everyone. I'll check out the 195/65-15 size. Also, Magnus' tires in the picture are Yokohama ADVAN A048s - they are specifically made for the track/competion.
    Cheers.
    Conny
    Quote Originally Posted by davewadd View Post
    I hope he's feeling better...
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Senior Member sweetE's Avatar
    Dec 2002
    Highlands Ranch, CO
    I've used both " BF Goodrich (g-Force Sport) and Yokohama (AVS ES100)" and they are very good for street and some auto-X work.
    I was amazed how stable the AVS ES 100's were in light snow!! If you are using 7" Fuchs, you may experience some rubbing in the front while turning.
    Dale Thero S Registry # 200
  1. Tire recommendation
    By Max (SD) in forum General Info
    Last Post: 02-23-2010, 08:12 AM
  2. Tire recommendation
    By EA911 in forum Technical Info
    Last Post: 06-11-2009, 09:39 PM
  3. Tire Recommendation
    By daepp in forum General Info
    Last Post: 01-21-2007, 02:03 PM
  4. Tire Recommendation
    By Chuck Miller in forum General Info
    Last Post: 07-09-2006, 07:37 AM
  5. Tire Recommendation for 69S
    By Mike Baum in forum Technical Info
    Last Post: 10-04-2003, 05:31 PM
