New to the forum. Cleaning house! Located in Charlotte, NC. NEW BATCH OF ELECTRICAL AND HARD ENGINE PARTS AND OTHERS.
VIEW ALL PHOTOS HERE: http://s200.photobucket.com/albums/a...rsche%20parts/
Alot of people want alot of this stuff, but no one seems to want to pay. I take Paypal, Postal Money Order, or even personal check if you're not in a hurry. I have been a 100% positive feedback Ebayer for over ten years. It's really simple. Tell me what you want, send me your private email addy, or call me, pay me, and it's yours. Don't know how else to put it.
EARLY TAILLAMP ASSY: Right side. 911/912. 1965-68. Not perfect, but nice. Missing one screw for lens. Slight tweak at very corner. 90163140401 $250
DOOR HANDLE RIGHT SIDE: 911. 1974-1989. Not perfect but nice. All there. 911531061/06200. $100
TURN SIGNAL SWITCH(2):
(1) 91161330501. 911 1976-1989, Turbo-1989, 912E. NEW IN BOX!! SWF. $100
(2) 91161330130. 911 1970-1973. SWF. Used. $100
ENGINE CONTROL UNIT: BOSCH JETRONIC. 0280800055. 911SC 1982-1983 ONLY. Except turbo. $200
ENGINE STUDS(60)USED 1965-1968:
(24) Of one kind, not sure of brand. $10 EACH
(12) Of one kind, coated. Not sure of brand. $10 EACH
AIR HORNS(12):
(1)Need cleaning, light polish: 50mm high X 46mm base I.D. X 63.8mm horn top O.D. 6.5mm bolt spacing. For 1969S I believe. May work for others. $100 SET/6
(1)Need cleaning, light polish: 30.4mm high X 45.2mm base I.D X 60.7mm horn top O.D. 6.5mm bolt spacing. $100 SET/6
AIRBOX: MFI Plastic. $200
ENGINE COVER: Plastic. MFI. $200
OIL TANK: 1978-1989 SC. Fits others. $250
1969S ALT/FAN PULLY ASSY: $100
A/C CONDENSOR: 1974-1983?? $35
ENGINE BOLT KIT: Used. $75 ALL
OIL COOLER SEALS: NEW. $80 ALL
INJECTORS (6): BOSCH 0280150158. 911 1984-1989 3.2, 944 ex. Turbo and 16V 1985-1988, 924S 1986-1988. $50.00 EACH. Cleaned and verified.
CDI TRANSISTOR IGNITION UNIT(2): BOSCH 0227200001. PORSCHE 90160270200. 911S 1974-1977. $200 EACH
HEADLIGHT SWITCH(2): No knobs. 91161302900/91161302901(new number). One old part number, one new part number. 911, 1974-1977, 911T 1976-1977. $20 EACH
DEFROSTER RELAY: Hella. 91161511500. 911 1974-1989. $70
WIPER RHEOSTAT: Has knob. 91161814701. SWF 911 1974-1989. $30
INTERVAL WIPER RELAY: 91161511200. Porsche. 911 1970-1973. $30
HORN RELAY: 91161511100. Porsche. 911 1970-1973. $30
FUEL PUMP RELAY: 91161815400. 911 1984-1989. $25
SHIFT KNOB: Any help here appreciated. Mystery.
VDO GAUGES COCKPIT(3): TEMP/PRESSURE/TACH. NEW IN BOXES!! Some small corrosion on two. $30 EACH. $85 SET.
CAM COVERS(2):
(1)Upper. 901105115OR. Marked 1973.5 CIS 2.4 $50
(2)Lower. 901105116OR. Marked 1973.5 CIS 2.4 $50
CHAIN GUIDES(9): 6 Embossed 1.2, 3 Embossed 1.1. Used $40 ALL
ALTITUDE SENSOR 944: 94460615100. $20
BOSCH FAN MOTOR: 0130002808. APK 12V. $20 Not sure what this fits exactly.
METAL FOG LAMP GUARDS(6): (4) 5 ¾” round. Could stand a respray. $25 EACH. (2) 5- ¾”X 3- 7/8” outside. 4-7/8”X 2-7/8”. Could stand a respray. $20 EACH
FUSE COVERS(2): One missing label. $30 EACH
BATTERY GROUND CABLES ORIGINAL(2): One slightly longer than other. $20 EACH
