Guys, I've just completed a major project on my stock 1972 911T, well, almost, which consisted of engine/trans removal and servicing/leak chasing, rear window seal replacement, parcel tray rust repair, engine compartment reconditioning, front end rebuild, pedal cluster rebuild, and shift linkage rebuild. I did all the work myself except for the rust repair and engine compartment restoration.
I was super-diligent in making notes, marking parts, and taking photos during disassembly in order to make reassembly easy. Unfortunately, my body shop threw me under the bus a bit - when the car came back from rust repair/engine compartment resto, there were two completely loose ground wires. Now, the only things left in the car when they had it were the fuel filter cannister assembly and the driver side mounting plate that has all the electrical items (relays, etc). I believe they temporarily removed those because they were loose when they came back, so my suspicion is that the ground wires are from there. Let's just say the body shop employees were of no use when asked later about these ground wires.
So, the drivetrain is back in, starter's wired up correctly, transmission ground strap is connected, constant 12V to starter - everything looks good, but a twist of the key does nothing - no solenoid click, NOTHING. I believe these ground wires are the root cause, but I'm not the best with electrical issues. I have a feeling the two yellow wires that activate the solenoid via the ignition switch are the primary issue and that a ground is missing for them....
I'm hoping you guys recognize the wires, using the pics below, and the general area of the car described above. Any thoughts?
Culprit #1: 9-1/2" long, brown wire, loop connector at both ends - one end accepts a stud for a 17mm nut, the other a 13mm. I believe this is p/n 911 612 008 00 (item #22 on page 426 of the PET PDF) - but I'm not sure how it connects.
Culprit #2: 13-1/4" long, braided steel strap, loop connector both ends, each accepts a stud for a 13mm nut.
Thanks in advance....Scott
