Thread: 67 911s ride height
    67 911s ride height
    Hello, I need to set up a 67S stock ride height. Can someone give me the numbers measured at the fender wells? Is there a diffence on a EURO car?
    Peter
    Oct 2010
    Sweden/Canada
    I think it's generally not recommended to set the ride height by the coachwork on these cars as there seems to have been considerable variations in their shape and fit.
    The numbers I've seen are wheel center to torsion bar center: wheel center 108mm above torsion bar center in the front and wheel center 12mm below torsion bar center in the back (36 degrees spring plate angle). These values are for an unloaded empty car.
    Goldmember ttweed's Avatar
    La Jolla, CA
    The numbers given by mikael above are correct for a street car according to the workshop manual. I have a PDF of the procedure archived on one of my websites if you would like to access it here:
    http://members.rennlist.org/tweedt/911RideHt.pdf
    Keep in mind that setting ride height should be part of an alignment and corner balance procedure, and that these settings are not absolute. For competition, many people deviate from the factory settings substantially, and ride height might be lowered.
    HTH,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. 72 T Ride height
    By Ccamut in forum Technical Info
    Last Post: 08-21-2013, 08:53 PM
  2. Ride Height
    By misterc in forum Technical Info
    Last Post: 03-22-2013, 12:42 PM
  3. Ride Height
    By boxster03 in forum Technical Info
    Last Post: 09-30-2005, 01:03 PM
  4. Ride Height
    Last Post: 05-21-2005, 04:21 AM
  5. ride height
    By scargo70 in forum Technical Info
    Last Post: 02-22-2004, 02:02 AM
