Hi Guys
I ended up with a set of tie rod ends with the crappy boots which have failed... Is there any solution to replacing the boots on these otherwise totally in spec rod ends, other than replacing the whole shebang?
I also have the same issue with one of my ball joint boots...
Cheers
