What is the story ona 902/16. I guess it was the optional box with the 6:29 ring & pinion. Are these desirable for any application?
1974 911"S" - Silver
10 sec 67 VW
Early "S" Registry #439
1969 912 5 speed.
Value ???
65 356SC Dolphin Gray
66 912 Green
69 911E Tangerine
72 911T GP White
72 911T Aubergine
72 911T Lilac
72 911S Black (voodoo)
90 964C4 Black Targa
94 964C2 Black Coupe
08 GT3 Speed Yellow
Yes, but it has some different gearing than standard and the 6:29 R/P.
10 sec 67 VW
Same a 902/06
A 11:34
GA 18:32
O 23:28
U 26:25
Z 29:23
It's still worth whatever you can get.
66 912 Green
69 911E Tangerine
72 911T GP White
72 911T Aubergine
72 911T Lilac
08 GT3 Speed Yellow
It's basically 70-71 911/01 5-Speed gearing, but in total ratio, it's more like the '65-68 902/1 A-F-M-S-X boxes.
It is desirable to someone who wants A-F-M-S-X total ratios, so in that sense, yes! But the pinion is almost always a weak point as you add power, therefore it's probably better to get actual A-F-M-S-X gears and use a 7/31 instead of longer gears with a 6/29. The pinion with fewer teeth is much smaller and therefore the load is distributed over a smaller area and it can break more easily.
However, if you have a reasonably (2.0/2.2) lower-powered car and you want to shorten the gears in a 1970/71, for example, swapping in the 6/29 Ring & Pinion gear is a pretty economical way to do it
I'd say value is approx. what any similar mag 901 gearbox goes for
scott kinder
kindersport@gmail.com
Registry #614
