Thread: LWB Front Rubber S Deco Trim with Overriders: Cut or Uncut?
    What's the correct way the front deco strip and rubber should be set up if I'm going to add overriders to a LWB 911? Trying to get this project done today but am unsure which route to go as I've seen both:
    Cut
    http://www.early911sregistry.org/for...read.php?66549
    http://www.early911sregistry.org/for...read.php?58213
    http://www.early911sregistry.org/for...read.php?49281
    Uncut
    http://www.early911sregistry.org/for...read.php?62169
    I'm inclined to go with uncut per Ed's comment in the first thread...
    http://www.early911sregistry.org/for...l=1#post501340
    ...but if I go this route, can I simply drill through the rubber and metal of my non-overrider strip? If not, does someone have a part number for the wide S deco strip for use with overriders? Thanks all!
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    My trim which I'm restoring at the moment is original judging from the state of it when I removed it, and it is uncut.
    If you cut it it will probably shrink, and never look right. The only problem is you want to go back to no over riders, you'll have to replace the rubber, as well as put a plug in your bumper.
    OMO Tony
    Quote Originally Posted by 911030 View Post
    Cut
    Uncut
    The deco insert is uncut when used with the steel overriders, just drill a hole through the rubber for the overrider bolt. For some reason the insert was split under the large 73 foam overriders.
  1. FS: NOS rocker deco rubber 1968 - 1973 and deco trim hardware
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 10:34 AM
  2. cutting rubber deco trim
    By 210bhp in forum Technical Info
    Last Post: 12-02-2011, 08:34 AM
  3. FS: 66/67 front overriders w/rubber insert
    By philvb in forum For Sale: 911 Parts
    Last Post: 08-12-2010, 09:49 AM
  4. Rubber behind deco Trim 69 T
    By Marktodo in forum Technical Info
    Last Post: 01-29-2009, 01:14 PM
  5. Rubber Deco Trim?
    By A.T. in forum Technical Info
    Last Post: 06-09-2006, 06:08 AM
