Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Does anyone use 225-50-16 on all four wheels?
    Senior Member Minoclan's Avatar
    Jul 2009
    Mendham Township, NJ
    I am putting RS flares on my 1970T. I have been toying with going to 17" wheels just because of 16" tire availability. I decided to stay at 16" with a 1.25" spacer in the rear. It seems that the number of tire choice opens up significantly if I use the 225-50-16 size on all four corners. I was wondering if anyone else had done this and what the result was.
    2007 GT3
    1999 996 Track RAT
    1970 911 T Tangerine
    R Gruppe Member
    911 S Registry Member #1609
    Dec 2003
    West Los Angeles
    I have a pair of new ContiSportContact 245/45 16s that a friend had said he was buying... but that was weeks ago and I haven't heard a word. That's a better size for the rear. 225/50 16 in front will require rolling fender lips and perhaps trimming the fender flange behind the turn signal housing. It may also require 1.5 degrees or more negative camber. For me, the ideal mix is 205/55 front, 245/45 rear. There's also one maker of 265/45, which will work on 9s.
    techweenie.com
    Aug 2005
    VA
    205 50 16's are the biggest that will fit inside the stock fenders using max camber. At least on my car and they are tight.
    Chris
    73 911 E
    Dec 2010
    Tulsa
    I run 225/45 - 15 hoosier all around for autocross, and it works very well; for high speed autocross or track, it's better to go to the 275/35 - 15 rears with 9" wheels.
    May 2005
    Oroville, CA
    We have build custom offset 16" wheels to fit the stock front fenders with 225/50s.
    Most racers use the 951 8X16 wheel but you will still need limited suspension movement and turning stops with max camber.
    H
    Jul 2009
    Quote Originally Posted by Harvey Weidman View Post
    H
    Have you seen 951 7's with the 225-50-16?
    2007 GT3
    1999 996 Track RAT
    R Gruppe Member
    May 2005
    Oroville, CA
    Quote Originally Posted by Minoclan View Post
    No, 951 7X16s are the same offset as the 911 7X16s...just more brake clearance. Not a good choice. IMHO
    H
    Jul 2009
    H
    I have them on the car now. I guess what you are saying is that that tire size is not a good choice for that wheel
    2007 GT3
    1999 996 Track RAT
    R Gruppe Member
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Cool
    225 fronts on 7x16 911 Fuchs with no clearance issues and 245s on the rear. I think that 225s all around would be unbalanced and leave one wanting more rubber on the rear. It's about balancing lateral grip.
    RGruppe #183
    I run 225 (15" wheels) on all 4 corners of my 1975 911s, and the flares are stock. 6" wheels up front, and 7" on the rear. No issues during autocross.
    "Speed never killed anyone. Suddenly becoming stationary...that's what get's you."
    1973 Austin Mini
    1975 911S 3.2 "the blue goose"
    1973 911E sunroof 3.2
  1. FS: Fuchs set of wheels from midyear 911 15 x 7 and 8" track wheels or refinish
    By scwhite59 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-22-2014, 02:39 PM
  2. WTT: two 7x15 Deep Dish R wheels for a set of four 4x4.5 S wheels.
    By obliviousmonkey in forum Free, Trades, and Swaps
    Last Post: 03-18-2014, 02:31 PM
  3. WTT: two 7x15 Deep Dish R wheels for a set of four 4x4.5 S wheels.
    By obliviousmonkey in forum For Sale: 911 Parts
    Last Post: 03-17-2014, 12:24 PM
  4. Replies: 0
    Last Post: 10-08-2012, 03:59 PM
  5. WTB mag minilite wheels or torque thrust wheels for SWB fitment
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 08-09-2012, 02:34 PM
