Hi again
I have a '68 with the hole provision through the nose for a sway bar but nothing on the A arms.
Is there a kit that bolts onto the A arm to accept the drop links or do i need to weld a bracket on?
TIA
Roland
Hi again
TIA
Roland
Hey Roland
Pelican has the tabs http://www.pelicanparts.com/cgi-bin/...34%2D%38%39%29 but I suspect Bob Whyms may have them also, and even more realistically you could make them using some cut box section. They have to be welded on...
I was trying to get to the post office this evening with the front sway, but let me now if a lack of U-tabs is a deal breaker...
John Forcier
EarlyS #1987
Restoration Saga
The mounting tab for the sway bar bolts on using the ball joint mount bolts.
A few pictures to go with Mr. Mayo's description.
Tony Proasi
52 split window coupe
not to steal the thread.. but anyone know where to find new swb ball joints for more modest prices than 220 a pop (that arent garbage)?
Harry Hoffman
356 Registry Member #36691
Mr. Mayo???????
That's Professor Mayo to we mere mortals! Here's a shot of the linkage assembled.
johnt
Great stuff guys! Thanks Ed
Roland, the only thing you'll need is the bracket in the photo, great to know it's just a bolt on... Personally I'd just make it (you know what I'm like ), but otherwise a call Porsche in Melbourne will tell you if they're NLA and I suspect an ad on this board will turn a pair up.
John Forcier
EarlyS #1987
Restoration Saga
Thats great news guys! Thanks for the pics. John please send down asap - im busting to try it out with my new rubber (what a difference).
Does anyone here happen to know where i can source those tabs?
John Forcier
EarlyS #1987
Restoration Saga
Bought a pair of tabs from Parts Heaven, last year, for my '68. I think they were $20.00 for the pair.
Tony
