Results 1 to 8 of 8
Thread: 1973 Window Surrounds (Anodize or Chrome)?
    I am in the midst of restoring a 1973 S and the window brightwork is in need of some assistance. In talking with several folks that I believe to have a good understanding of Porsche history, I was told that while the brightwork was primarily anodized, it was available from the factory in chrome. This had clearly been done in prior years, but I am trying to obtain verification that chrome was indeed an option for the window surrounds in 1973. Any thoughts out there? If anodizing is the "proper" solution, any recommendations of a shop to do this work? To date, finding someone who had not had an issue with anodizing has proven difficult (and has perhaps driven my inquiry toward the "chrome option").
    Thanks in advance for your help!
    Lightbulb
    scolson,
    I have not heard of a 'chrome option' for the bright work of our later-early cars. As far as I know all '73's came with clear anodized bright work.
    Many on this board have used King of Trim (old name was Ano-Brite) with very good results.
    I have personally used them for 19 pieces of original anodized trim on my '67 Malibu... they all came out perfect.
    They are other options... but very few.
    http://www.kingoftrim.com/home.html
    Hope this helps
    Jan 2003
    UK
    If your '73S happens to be a Targa model, it would have come with chromed brass door window frames (with opening quarterlights)
    Andy
    Early 911S Reg #753
    R Gruppe #105
    As far as I know...
    Glad I put that in Andy.... Didn't realize that they were still doing the chromed brass on Targas by the 2.4's
    I learn every day... and it's probably on this board somewhere......
    Now, were the Targa frames still anodized as well? I don't recall the look on the '73 Traga trim any different than the coupes....
    Cheers
    Jan 2003
    UK
    Chuck - '69-'73 Targas still used chromed brass door window frames (you can't anodise chrome or brass - only aluminium/aluminium alloys) - presumably because it was 'stiffer' than aluminium (which was needed due to the lack of a top section of the window frame in Targas).
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Do the targa frames have a different contour or shape than the ones on the coupes do?
    Junior Member
    Dec 2011
    SoCal
    If the car is a coupe the trim should be a process called Bright Dip.
    May 2005
    Oroville, CA
    "Do the targa frames have a different contour or shape than the ones on the coupes do? "
    Yes, coupe frames go around the door glass. Targas stop at the vent upright.
    Coupes were chrome up to and including 67 and bright anodized aluminum after. Black available 74>
    It is a difficult process, but KOT seems to have it down.
    H
  1. FS: Nice pair of HELLA US Chrome Headlight surrounds
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 02-03-2014, 08:52 AM
  2. FS: Multiple switch inserts and surrounds
    By s2guy in forum For Sale: 911 Parts
    Last Post: 12-26-2013, 12:48 PM
  3. Replies: 4
    Last Post: 10-09-2011, 02:09 PM
  4. Anodize / Chrome Recommendations
    By 911xom in forum Technical Info
    Last Post: 08-17-2011, 08:03 PM
  5. FS-NOS early chrome window frame with vent window
    Last Post: 02-27-2010, 03:58 PM
