Results 1 to 8 of 8
Thread: Euro/ROW Gauge Question
    Port Macquarie, Australia
    Hi All
    I have my gauges at Nth Hollywood for restoration and I'm converting my Sporto temp gauge to S spec. My car is an Australian (metric) delivery, but should be pretty close to ROW spec... Should my temperature gauge read in Celsius or Fahrenheit, and pressure in BAR or PSI?
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Hi John,
    My 1970 car has Euro S-spec gauges. From left to right:
    1. Combo "Tank" (R, 2/4, 4/4) & "Oel" (5, 6, 8 liters)
    2. Combo "Temp" (50, 80, 100, 120, 150C) & "Druck" (0, 2, 4, 6, 8, 10 Bar)
    3. Tach
    4. Speedo (km/h)
    5. Clock
    I'd attach a picture, but whenever I do that here my posts get quarantined. I can email or PM you one.
    Cheers,
    Mike
    Mike Caterino
    1970 T targa
    Santa Barbara, CA
    restoration blog: mk911.blogspot.com
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    My Australian delivered 73 with S gauges have the temp 50 to 150 (must be C but it does not say it) and pressure (marked "Druck") up to 10 bar as per mikes above
    However i am not sure if these changed over time in Australia, if mine was a replacement, or both types were delivered as I have seen Australian delivered cars with S gauges in Fahrenheit temp and pressure gauge marked "press" with the scale from 0 up to 140
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Thank you both!
    I guess I have the luxury of specifying what I like Harmut at NH Speedo has either available... I'll go with C/BAR based on my school lernin'
    John Forcier
    EarlyS #1987
    Restoration Saga
    Feb 2007
    Bondi Beach,Australia
    john,
    My car is Australian delivered '73 911E and all guages are the same as mcaterino, above.
    Hope this helps.
    Peter KaufmanN
    '73 911E Targa rebuilt as 2.7 MFI
    '73 911T Coupe rebuilt as 2.7 Webers
    '04 SUBARU WRX (not standard)
    Thanks Peter
    I've asked for Celsius gradients on the temp gauge, but given the pressure is reading happily in PSI, I figured I'd leave it alone...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Dec 2004
    Melbourne Australia
    you just want to be different don't you C on one side and PSI on the other
    I am not sure I have ever seen THAT combo
    is your current pressure gauge marked "PRESS" or "DRUCK" ?
    Hugh Hodges
    73 911E
    Melbourne Australia
    Pretty sure it's Pressure...
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. Euro '73E Gauge Set
    Last Post: 05-27-2012, 11:35 AM
  2. FS: Euro Temp/press oil gauge
    By OliveR in forum For Sale: 911 Parts
    Last Post: 10-20-2011, 11:17 PM
  3. European gauge question
    By 911quest in forum Technical Info
    Last Post: 05-09-2009, 04:52 PM
  4. Another Outside Temperature Gauge Question
    By hdavis in forum General Info
    Last Post: 12-16-2008, 08:44 AM
  5. 1971 911S euro gauge set
    By glaverbel911 in forum For Sale: 911 Parts
    Last Post: 02-03-2008, 02:06 PM
