Results 1 to 10 of 11
Thread: RSR gearbox oil cooler pump install
    Feb 2011
    Northern VA
    Over the years I have collected all the bits -- the pump gears, casting, snorkle, pipe, gaskets an now hose... Now, does anyone out there in S land have a diagram, fitting mesurments etc, to put it all together? I'm figuring the factory had to have a buletin sometime or somewhere?
    Thanks in advance
    I believe the shop manual shows the fitting of the oil pump in the nose cone.
    Aug 2007
    Phila Pa. area
    The shop manual does show it, as Edmayo says. It shows the nose piece that does not use the front mounted cooler. However I believe the specifications are identical. I have copies of the instructions if you need them. Also I have the whole setup with the front cooler. I have some extra pieces also, hard and soft lines,steel fittings, and Argus fittings
    Mike
    Install of pump and pump w/cooler are the same. All you have to figure out is where you want to put the cooler.
    -Marco
    TLG Auto: Website
    there's a little about this with some pictures at the bottom of page 2 of my engine build, if it helps.
    http://www.early911sregistry.org/for...i+engine+build
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Feb 2011
    Northern VA
    Thanks a lot. I will thumb through my manuals. And make sure I have it. The only part I DON'T HAVE is the cooler. I was planning on using a Setrab w fittings to match the factory hoses. I will likely put the cooler in the engine bay, like several of the privateer SC rally and factory SC/RS rally cars. Not the coolest place for it, but likely the safest? Alternative is rear wheel well?
    Aug 2007
    Phila Pa. area
    The RSR puts it in the front of the drivers fender, basically a serpentine engine cooler. I could send a picture if it helps. The soft lines go from the trans to just in front of the swing
    arm on the driver side, hard lines from there to the front of the fender, short lines to the cooler.
    Mike
    Feb 2011
    Northern VA
    I would love to see a picture. Thanks
    Here's a picture of my RSR oil cooler loop. You'd think it would be a standard right hand loop turned round,
    sadly not as easy as that, it is specific for the RSR.
    cheers, Mike
    Member#1664
    Aug 2007
    Phila Pa. area
    cooler picture
    Here is a picture of my cooler
    Quote Originally Posted by mike curnow View Post
    Mike
  1. Trombone Oil cooler install: where to drill?
    By neilk in forum Technical Info
    Last Post: 04-17-2020, 03:04 AM
  2. FS: Very Rare....RSR Gearbox Oil Cooler Loop.
    By Mike_Moore in forum For Sale: 911 Parts
    Last Post: 11-27-2013, 07:17 AM
  3. Should I Install a Smog Pump on my '68?
    By mshaver51 in forum Technical Info
    Last Post: 06-09-2010, 07:03 PM
  4. WTB: Parts for Front Oil Loop/Cooler Install
    By RTincher in forum For Sale: 911 Parts
    Last Post: 11-15-2005, 01:59 PM
  5. DIY install of external oil cooler questions...
    By bob tilton in forum General Info
    Last Post: 06-02-2005, 09:20 PM
