Thread: 2.0N vs 2.2S Flywheel and Clutch
    RE: going from a 2.0N to a 2.2S
    Is the flywheel, pressure plate and clutch disc; form, fit, weight and functionally the same? Or how do they differ?
    50/50
    Jan 2003
    UK
    No - the 2.0 litre models used a 215mm clutch & a flywheel with integral ring gear whereas the 2.2 litre models used a 225mm clutch & a flywheel with separate (bolt-on) ring gear.
    With engine swaps you essentially need the flywheel/clutch which goes with the transmission you're using:
    901 transmission - 215mm clutch/flywheel
    911 & 915 transmissions - 225mm clutch/flywheel
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Thanks Andy
    Don't the 70/71 2.2 models have the 901 Trans? I thought that the 915 series began in 72 with the 2.4 series. Is the weight/profile of the flywheel the same?
    Regards,
    Larry
    Jan 2003
    UK
    Larry - the '70/'71 models had the '911' version of the 901 transmission with a 'pull' type (225mm) clutch.
    The design/weight/profile of the 2 types of flywheel is quite different.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. WTB: 2.0 flywheel and entire clutch kit
    By eaton in forum For Sale: 911 Parts
    Last Post: 12-20-2013, 10:40 AM
  2. Clutch and Flywheel for a 70/71 911 Gearbox
    By Rob B in forum Technical Info
    Last Post: 08-30-2013, 06:05 AM
  3. F/S Fidanza 901 Aluminum flywheel with tilton 5.5 twin disc clutch
    By Thorshammer in forum For Sale: 911 Parts
    Last Post: 03-07-2010, 04:01 PM
  4. 906 flywheel, clutch, and pressure plate?
    By JPlonghood in forum Technical Info
    Last Post: 11-12-2009, 03:48 AM
  5. FS - 2.0L clutch/pressure plate/flywheel
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 09-24-2009, 12:28 AM
