Results 1 to 7 of 7
Thread: Flywheel Lightening??
    I am considering lightening a flywheel for a 2.2S motor for sporty street use. It is from a 2.0N and weighs 13.1#'s. Any suggestions? Not looking to go too radical at the cost of drivability.
    50/50
    Hi,
    Just in case it helps with weight info, for street use we make these new ones.
    http://www.canfordclassics.co.uk/gal...wheels-6-bolt/
    HTH
    Alan
    If I read you correctly although you are using a 2.2 engine it sounds like you're using a 2.0 flywheel. If that's the case you can remove 3 to 4 lbs and not hurt the driveability. It should all be removed from the outer edge, do not remove any from around the mounting area, all you do is weaken the mounting and it will crack there. Do NOT try to lighten the 2.2 style flat face flywheel, it is cast steel and doesn't take well to lightening, buy a steel one from Alan.
    New early 2.0 litre flywheel with induction hardened teeth, lightened and balanced to G2.5.
    That looks great. Is it an exact copy of the 906 flywheel? What's the difference in weight compared to a stock one?
    Chris Mulder
    Thanks Ed
    Although the flywheel was machined around the circumference and it only yielded a .8# reduction.
    Chris:
    An impressive show of machining and balancing. Who did the work?
    50/50
    Sep 2006
    La Quinta
    Cris,
    Where can I get one?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  1. ID this flywheel please
    Last Post: 10-25-2011, 07:44 PM
  2. Flywheel lightening
    By andyjboy in forum Technical Info
    Last Post: 06-03-2010, 06:28 AM
  3. Lightening the Posterior
    Last Post: 01-20-2009, 06:37 PM
  4. SWB lightening: Leave out Front Corner Weights?
    By TargaFlorio in forum General Info
    Last Post: 10-01-2008, 08:24 PM
