Thread: 68 911 L rear brake calipers ?
    Aug 2011
    Orange County ,Ca
    Does anyone know what rear calipers are on a 68L? They look like 912 rear calipers with a spacer for vented rotors. The pistons are 38mm. I tried ate part# 13.0441-3502.2 but the inner seal broke upon installation. So either I made a mistake installing or they are the wrong pieces. I just did the front brakes with no problem. Any ideas would help.
    Quote Originally Posted by Early Porsche View Post
    Do a search for wide L rear calipers. Neunelfer (Eric / PMB performance) has posted a nice thread about the L / S calipers.
    RIchard
    Did you compare the piston seal size diameter of the old vs. new? Sounds like maybe the wrong kit and seal diameter.
    38 mm piston is correct for the wide L
    Richard
    The L model had the same suspension and brakes as the S, as does all sporto models.
    HTH
    Alan
    Aug 2011
    Orange County ,Ca
    Thanks. .
  1. FS: Rear M Brake Calipers
    By Bert in forum For Sale: 911 Parts
    Last Post: 04-04-2014, 02:22 PM
  2. Idenifying My Rear Brake Calipers
    By shipard in forum General Info
    Last Post: 11-21-2013, 09:22 AM
  3. FS: '68 912 Rear + Front Brake Calipers
    By rothaus in forum For Sale: 911 Parts
    Last Post: 08-23-2010, 04:29 PM
  4. Wanted 67S or 68L Rear Brake Calipers
    By Tim Morris in forum For Sale: 911 Parts
    Last Post: 07-21-2010, 01:06 PM
