Results 1 to 8 of 8
Thread: Correct early wire guide locations
    Physics Guy oscillon's Avatar
    Sep 2010
    Washington DC
    Hey All,
    I have a question about the proper location for the plug wire guides on early weber cars (66-67). These are the round rubber grommet style that have a flat tang with a mounting hole. I see a lot of pictures of the left side locations that people choose. One location on the left is down by the duct that connects to the shroud where there is a hex head bolt. The other left side location is through the shroud around the middle position. On the right side, which is always slightly less clear in most photos, the mounting position seems to be on the stud that protrudes from the head that the carb manifold mounts to.
    What are the correct positions? I've attached a photo of the lovely '67 normal that was for sale on the board a bit ago, and the guides here seem to follow the lower position on the left shroud side, and from what I can discern from the right side, it's bolted to that stud. There is also a picture from a recent post that shows the left side in the middle position on the shroud ( I realize those are solex carbs, does that make a difference? ).
    Any photos/insights would be great!
    Dan
    Name:  solex fitted.jpg
    ______________________________________________
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    A photo FYI...1966 911 with webers.
    Leon Kreger
    Sep 2010
    Washington DC
    Thanks! That's certainly another data point for the left side location. Unfortunately, I still can't see anything on the right side...
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    1966 911 Engine
    Right side...
    1966 911 engine right side view
    A little closer...
    Sep 2010
    Washington DC
    Awesome! Thanks for the shots of that lovely lump.
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    LOL Dan I was considering precisely the same question when mounting my wires the other day! The left one points straight back and the right one goes on the manifold stud, I'm pretty sure.
    Apr 2008
    Virginia's Blue Ridge
    The left one always looks to be canted about 30* toward the outside -- somewhat following the natural path of the wires.
  1. Replies: 1
    Last Post: 06-17-2013, 10:37 AM
  2. Early SWB mirror locations
    By StephenAcworth in forum Technical Info
    Last Post: 12-19-2012, 09:29 AM
  3. early SWB oil line "pipe clamp" locations
    By Neil '67 911S in forum Technical Info
    Last Post: 07-29-2010, 01:29 PM
  4. WTB: Early throwout bearing and guide tube for my '68
    Last Post: 01-22-2009, 03:15 PM
  5. Need Correct 915 Guide Tube Seal
    By Dezzmo in forum Technical Info
    Last Post: 12-02-2008, 11:58 AM
