Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: New item, correct grey foam seal for the SWB horn grills....
    Seattle WA
    It's the little stuff that counts!
    This is the correct grey foam "tulip shaped" seal for the SWB horn grills (both standard and fog style). Note that I don't see this fitting the LWB grills.
    Couple of pics. I'll pick it up in 10 days, and will quote price then, but figure about $10 for enough to do both grills. This is a small run item, and tooling this was $$.
    On a side note I've got a lot more coming, but there's quite a few items that won't see the light of day. Tooling costs for most of these items I have done are really expensive, and sometimes it just doesn't make sense to spend $5000 to tool up for a $10.00 item, and then hold inventory for many years before you can even think about breaking even. I don't know how the likes of Stoddard/356NLA can do this on the scale they do....
    cheers, and thanks for all your continued support!
    Yes, I'll have this and everything else at the LA lit show and swap meets.
    Eric
    Thumbs up
    GREAT ITEM!
    I appreciate you make this available.
    I look forward to it being available
    Richard
    Apr 2010
    Kalimantan <SeaTac<Philly
    Good on you, Eric!
    Aug 2005
    Bucks Co., PA, USA
    VERY nice. Hopefully similar for LWBs will appear in the future!
    ESR #1474
    The only drawback is removing the black "modern" seal that I glued on! Good on you Eric! Count me in when you're ready.
    Physics Guy oscillon's Avatar
    Sep 2010
    Washington DC
    sign me up! as always great stuff.
    ______________________________________________
    Dan B.
    1966 911 black/red
    1966 912 slate grey
    1996 993 black/tan
    Feb 2005
    Lake Tapps, WA
    Eric, put me down for a set also.
    Chris
    EDIT, I could use a few more sets if you end up having some extra material.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    Nice! Count me in for a set Eric.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Sep 2008
    Monza, Italy
    Great! 2 sets for me. Thank you
    Registry Member #1414
    NOSGRUPPE
    Seattle WA
    Quote Originally Posted by andrea70 View Post
    Sorry Andrea, I can't sell these to you as they are not NOS!
  1. LWB Horn Grille Seal Details?
    By teenchy in forum Technical Info
    Last Post: 05-25-2020, 08:22 AM
  2. FS: One Air Horn for SOLEX 911 and rubber seal for air box
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 03-17-2014, 02:08 PM
  3. Replies: 7
    Last Post: 10-14-2013, 09:57 AM
  4. Solid Door seal correct 45 degree cut and glue.6
    By Rino71 in forum Technical Info
    Last Post: 09-29-2013, 06:20 AM
  5. Need Correct 915 Guide Tube Seal
    By Dezzmo in forum Technical Info
    Last Post: 12-02-2008, 11:58 AM
