Results 1 to 7 of 7
Thread: 914-6 turn signal switch ??
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    My 914-6 has a balky one. My mechanic tells me the 914-4 and 914-6 turn signal switch assembly is NOT interchangeable and I would have better luck adapting a used 901-assembly, although he says that is a lot of work, also. Really? Not that I don't believe him, but why would they be any different, especially if for the same year? I am aware that the 914-4 had the ignition switch on the steering column, but does that affect the turn signal switch. Thanks gurus!
    - MR
    Junior Member
    Dec 2011
    Fresno, CA
    I don't have the answer, perhaps others here do, but you may want to post your question on the 914World. There are number of 914-6 owners there.
    Good luck,
    keith
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Good idea, Keith. Thanks for the suggestion. (I'm so used to going here as an information source, I almost forget thre are other good sites out there, too )
    - MR
    Your mechanic is right. The 914-6 used an entirely different steering column.
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Thanks guys for the input. I'm not sure what the problem is, but mechanic seems to think beyond repair. Perhaps damaged by aftermarket steering install. Will find more out when I talk to him again.
    - MR
    I haven't tried yet, but I always figured I'd graft an early 911 switch and half-loom onto the 914/6 plug and half-loom should the need arise.
    PM Sent
    -Marco
    TLG Auto: Website
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Quote Originally Posted by Mr9146 View Post
    PM Sent
    That sounds like a possible option, too. Responded to PM, thanks.
    - MR
  1. FS: turn signal switch '65 - '67
    By typ901 in forum For Sale: 911 Parts
    Last Post: 01-06-2013, 08:24 PM
  2. WTB: Turn Signal Switch
    By rajaro in forum For Sale: 911 Parts
    Last Post: 12-31-2012, 05:59 PM
  3. FS: Turn Signal Switch SWB 911/912 65 -67
    By 67softwindow in forum For Sale: 911 Parts
    Last Post: 01-02-2009, 06:56 PM
  4. 69 turn signal switch, left turn works, right doesn't
    By caproader in forum Technical Info
    Last Post: 06-04-2008, 05:30 AM
