Thread: Clutch cable removal
    Nov 2010
    Harleysville, PA
    I am removing my engine and trans - 67.
    One step is to remove the clutch cable. How does it disconnect? I see the nut on the end of the clutch cable (where it interlocks with the lever that goes into the trans), but when I turnithe nut, the whole thing turns, including the cable.
    Is there a trick or some way to hold the other end from spinning? Or is there another place I should be disconnecting it?
    1967 911S - 306465
    1980 911SC
    2005 Carrera Cabriolet
    You use a small vise grip on the unthreaded portion of the cable to keep it (the cable) from turning.
    Nov 2010
    Harleysville, PA
    Thanks Ed.
    I finally got it disconnected!
    1967 911S - 306465
    1980 911SC
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    You might want to consider replacing the clutch cable while you are at it, unless you know exactly how old and what condition it is in. Trust me - it's much easier to deal with it now than at some unexpected time in the future.
    - MR
  1. Clutch Cable Lengths SWB vs LWB
    By Jury in forum Technical Info
    Last Post: 01-20-2013, 08:01 AM
  2. FS - New, unused 70-71 clutch cable
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 11-11-2011, 05:46 PM
  3. FS 70-71 new Clutch Cable
    By Carrerax in forum For Sale: 911 Parts
    Last Post: 08-02-2010, 10:11 AM
  4. FS: Post SWB clutch cable
    Last Post: 10-25-2009, 07:53 AM
  5. speedo/ odo cable removal
    By fuegos100 in forum Technical Info
    Last Post: 06-01-2004, 06:50 PM
