Thread: Electrical Panel Rebuild
    Does anyone know off a resource to refurbish electrical panels?
    50/50
    The fact that 44 people (at the moment) have read this and not offered an opinion suggests that no one knows what you are talking about. Which electrical panels? Why not just paint or powdercoat them? Or do you mean the fuse panels themselves? A little background on your problem would be helpful.
    jhtaylor
    santa barbara
    Fair question. The panel which I am referring to is mounted in the engine bay and has (depending on the model) CD box, Coil, Relays,voltage regulator etc. I figured that there are specialists that repair/refurbish calipers, pedal assemblies, steering wheels, carbs, distributors, MFI and so forth. Electrical panels anyone?
    Jan 2011
    DFW TX
    Its mostly a wiring harness back there (at least on my LWB cars)... big rectangular plug on the bottom of the console is wired to multiple small sockets for the relays etc and loose wires for the fuse block and CD/VR/etc and to the big plug on the back that goes to the engine harness. You can do a lot yourself by carefully dissassembling and cleaning the plugs. For more in depth problems someone who does wire harnesses should be able to help.
  1. 69E Electrical Panel
    By Djthom in forum Technical Info
    Last Post: 08-21-2013, 06:56 AM
  2. WTB: 2.2 Electrical Panel
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 02-06-2012, 01:38 AM
  3. FS: 3-pin CD; 73-73 engine bay electrical panel
    Last Post: 07-24-2008, 02:47 PM
  4. FS....67 electrical panel
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 06-16-2008, 07:56 PM
  5. Is this an 67S electrical panel??
    By X-Faktory in forum Technical Info
    Last Post: 06-09-2008, 06:00 PM
