Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: do i / don't i - behr fender coolers repos
    Sep 2008
    Auckland , New Zealand
    With my day job taking up way to much time i've had to slow on the st parts but as i needed to work with china for product manufacture for my day job i put the feelers out for reproducing the behr fender coolers rhs/lhs for ST - RSR set ups . What i have found is that yes it is possible to make exact copies of these and yes easy to be rhs and lhs versions. the cost to make them is low ......
    BUT the set up cost is not cheap and most likely i need to go to china to set this up , is there enough interest in making these to warrant such a cost and time out lay ( next year not this year)...? what do you think
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    What does the retail price need to be?
    Sep 2008
    Still need to sort import tax and shipping , at a guess I would need to sell 35 units at 500 retail
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Apr 2011
    Germany
    Freisinger / Germany charges 1800 Euros now what is about 2350 USD per unit of the 2.0 / 2.2 S oil cooler! thats 4700 USD for the set and he has only the right one, so labour cost and risk to damge one for welding the left side brackets is another theme!
    I need 2 sets!
    Porsche 911 S 1971 Kremer race car
    I would be in for a set John assuming you mean the bigger 30mm 72 style
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Aug 2007
    Phila Pa. area
    coolers
    The factory 1973 RSR does not use those coolers on either side. The engine cooler is a big one in the nose, and the transmission cooler is a serpentine in the drivers front fender.
    Mike
    I'm sure the Chinese are capable of making a good quality product. BUT with a critical part like an oil cooler, I wonder if people are more concerned with something that LOOKS right, but is made in China, or if they would accept something that looks almost right, but uses a proven, good quality modern cooler that is adapted for the job.
    Have you spoken to these people? http://www.pwr.com.au/#/view=home/
    cheers
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    Sep 2008
    hi jeff , you are right there which is part of dealing with china made goods hands on. From experience with product manufacture and supply from china if you don't inspect , inspect, inspect everything they will try it on . i have been having pumps made and shipped for 13 years direct , so far i have changed suppliers 4 times as at the start you get a fantastic product , then not so good , and then a bit less ... as they try to make more money by installing lesser quality internals without telling you.
    IF i look at doing this Every unit will be checked , tested before sale trust me . when it's for a porsche it's to critical to be perfect rather than probably ok .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    update; Taking on board the issue with China products i had a chat with a alli welding guru / fabricator over here in nz . i advised what we are trying to achieve and he is quite upbeat about how to proceed. the core is easy , the top and lower tank a bit harder . i think the best we can do is use ridged ali for the look , and match the outline shape as per original plus make and weld in the correct connectors .as such so far so good to be new zealand made.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    Just an FYI- I once bought a Chinese copy of the engine oil cooler. When I recieved it, sand came out of it when I took it out of the box.... I returned it and never used it.
    Chad
    911ST Race Car w/2.5L SS race motor.
    1972 911 T- Original numbers car- restoring it
    2016 Elan NP01 Prototype Chassis #20; Car Number #02
    2011 Porsche Spyder Wht/Blk/ Carbon Fiber Buckets (Sold)
    Powered by Faragallah (Aase Motors)
  1. WTB: 69-71 S Behr fender oil cooler
    By stretch in forum For Sale: 911 Parts
    Last Post: 04-05-2014, 08:58 AM
  2. Fuchs wheels vs. repos...
    By StephenAcworth in forum Technical Info
    Last Post: 01-01-2013, 06:28 PM
  3. WTB: Right hand fender extension - to back date later fender
    By Andy 74 in forum For Sale: 911 Parts
    Last Post: 06-19-2012, 04:50 PM
  4. WTB lwb 911s behr fender oil cooler
    By advtracing in forum For Sale: 911 Parts
    Last Post: 02-25-2011, 09:39 AM
  5. FS 69-71 Behr S fender cooler
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 01-26-2011, 07:16 PM
