Results 1 to 10 of 11
Thread: My Restored Gauges
    Port Macquarie, Australia
    My Restored Gauges
    I'm sure you've all seen North Hollywood Speedo's work... Well here's some more
    Some personal tweaks include șC temperature scale, and a 'backdated' speedometer for my 915 box. My clock is now quartz and the tacho reads a MSD signal to a 7200 redline
    John Forcier
    EarlyS #1987
    Restoration Saga
    Very very nice! I am considering doing something similar on my 72 911T with the kms and Celsius as we also use the metric scale in Canada. Plus I hate the fact that my clock is non-operational.
    May 2004
    Dallas, Texas
    Look great. How long did it take North Hollywood Speedo to restore the guages?
    Robert
    Feb 2010
    San Francisco, CA
    Looks really nice! I had my gauges redone a few months back by Hartmut @ Palo Alto Speedo. Also a stunning job that really cleaned up the cockpit.
    Turns out that Hartmut @ PA Speedo was named after Hartmut @ NH Speedo. Hartmut's father (the younger @ PA Speedo) was a long time friend of Hartmut (the elder @ NHS). Small world in the speedo biz eh?
    Cheers
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Aug 2007
    Phila Pa. area
    prices
    This would be a lot more interesting if you told us the price to get these gauges re-done
    Mike
    Quote Originally Posted by mike curnow View Post
    Fair enough. Your cost will vary depending on the condition of the base units... Mine were 'old and crappy' - dirty, sticking needles, clock not working. My cost was $1290, but involved
    Converting a later electronic speedo to look pre '73 including mounting studs to fit it into my '69 (no rubber grommets), I run a 915 box.
    New Tacho PCB with 7200 redline and MSD compatibiity
    Clock converted to quartz
    Converted temp gauge from sporto to 300 0C numerals (I like metric) plus sender.
    All new 'artwork' - dials reprinted and repainted needles
    All bezels replaced (no gouges or screwdriver marks )
    Plus I had to freight them to and from the US.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Feb 2010
    San Francisco, CA
    As John said above, the cost really varies depending on what exactly you have done.
    Regular function check and clean (which includes repainting the needles) + a new outer bezel is something like $55-$60 per gauge.
    Now, if you have an issue with an instrument, the price goes up. I had a bad pot metal gear in my speedo... this cost $120 on top of the clean and bezel
    I needed to have a capacitor and diode replaced in my Tach... this cost $153 on top of the clean and bezel.
    My clock was already quartz converted (which actually started the whole cleaning frenzy. It made all of the other gauges look dirty)
    I didn't need to have any of the faces re-screened or cleaned, and I had Hartmut not clean the backs in order to maintain the ink date stamps and paper tags.
    All out the door, I paid $499
    Not bad as I needed up with gauges that look and function like new.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Nov 2002
    Worshington State
    Your gauges look tremendous, factory fresh.
    I have a small bird chirping in my speedo. It is appeased by a little oil, but the chirp returns. If I send it off and it comes back as nice as yours, of course I will be forced to send in the rest. What a dilema.
    Rick, that was exactly my dilemma. I started out just wanting the electronic speedo sorted for my car; then I figured I'd get the redline sorted for my RS spec engine. Hartmut explained that the tacho would get a new face and may not match with the others. So I decided to have all done to match. Once they arrived at NHS the oil and temp were found to be sticking. So I just though I'd go with everything including the quartz clock...
    The quote was the final price and I couldn't be happier with the work. It is a big hit to my resto budget, but bad gauges really stand out in a restored and reupholstered car!
    John Forcier
    EarlyS #1987
    Restoration Saga
    Always nice to look at a set of restored gauges!
    How much does North Hollywood Speedo's actually charge to fully rebuild gauges?
    - twinplugged - 1975 targa former Dutch police car
  1. FS: Gauges 930
    By Minkoff in forum For Sale: 911 Parts
    Last Post: 10-12-2013, 10:41 AM
  2. gauges FS
    Last Post: 12-01-2012, 04:34 AM
  3. FS: Gauges
    Last Post: 10-01-2012, 12:35 PM
  4. Green Gauges Restored by North Hollywood
    By 304065 in forum Technical Info
    Last Post: 04-23-2010, 06:11 AM
  5. T to S gauges
    By Polizei in forum Technical Info
    Last Post: 10-02-2008, 03:05 AM
