Thread: washer pump for MY 1968 mounted on the floor
    Senior Member egbert's Avatar
    Mar 2007
    Amsterdam
    Hi All,
    Do they still make these nowadays?? Mine is seriously leaking
    It is mounted on the floor next to the washer bottle
    Any help appreciated
    rgds egbert from holland
    You can still buy them but they don't look like that. What is the date code stamped on yours? It's on the metal plate on the end.
    Try 928.628.074.01
    They are about $60
    Mar 2007
    Amsterdam
    It says 01 67, it's an oldie
    The problem is that they look different indeed so that's why the thread
    Does the 928 no. looks close to the one I have/want?
    rgds egbert
    Egbert they look like this, Siemens/VDO moved the outlets to the inboard side
    Mar 2007
    Amsterdam
    Ok thanks, I have seen these
    rgds egbert
    Feb 2011
    Surrey, UK
    Where does it leak from? I assume around the metal flange on the end. If so try taking it apart and using some gasket sealant on the joint.
    These early pumps have the advantage that they can be dismantled (with care) and so you might be able to fix the problem - mine was seized after many years of inaction, but I have it going again now.
    Mick
  1. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  2. FS: 1968 Washer Bottle w/pump
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 03-06-2014, 08:34 PM
  3. WTB: washer bottle with pump
    By gregbus in forum For Sale: 911 Parts
    Last Post: 10-07-2011, 06:48 AM
  4. electric Fuel pump for MFi mounted
    By MY911S in forum Technical Info
    Last Post: 09-20-2010, 10:46 AM
  5. 67 washer pump
    By tomkirkcis in forum General Info
    Last Post: 05-30-2007, 12:59 PM
