Thread: 911R Lamp Housings
    911R Lamp Housings
    Most of the photographs of 911Rs seem to show lamp housings that are fitted with screws holding them to the body.
    There are also housings being sold without any screw fitting features that are said to be genuine.
    The shape of the two types of housing are also quite different.
    The 'Genuine housings' dont have enough space between the inner lamp and the edge of the housings to take a screw and the profile of the edge is much closer the the shape of a SWB cars body work than the screw on type.
    I had the impression that the 911R originally had lamp housings that were bonded in place and that the steel compartment used on the SWB cars would have been cut away to allow fitting.
    I am sure someone knows the answer.
    'Genuine' and Screw Fitting lamp housings
    Screw Type showing trimmed edge that would suit later bodyshells
    Curved edge that would fit correctly on SWB shell
    Not to be didactic, but I believe that both of the pictured housings are recreations; designed for use in cars with steel bumpers. As a replica, the upper is better, but not accurate. True R housings have both a more rounded inner, lower corner (yellow) as well as a more rounded outer lens platform (violet). There is also a sloping transition between the two light platforms (green) which is rounded instead of straight (orange). The two screws both mounted perpendicular to the surface, attaching to small sheetmetal plates welded to the edges of the fender recess. NOS housings have 1/2" long perimeter flanges that have to be ground to fit the car.
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    I actually liked the 'screwless view of them.
    We put some struds on the back to mount the in the original taillight location.
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
  1. FS: 911R tail light housings and bulbs
    By ETW in forum For Sale: 911 Parts
    Last Post: 03-04-2014, 05:43 PM
  2. Hella 911R lamp & lens oddments
    By andyjboy in forum For Sale: 911 Parts
    Last Post: 04-09-2012, 10:10 AM
  3. 911R lenses and lamp bases
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 12-17-2010, 04:37 PM
  4. 911R Front Lamp kit w/brake duct
    By Mark Morrissey in forum For Sale: 911 Parts
    Last Post: 09-07-2008, 07:33 PM
  5. Replies: 2
    Last Post: 02-12-2007, 01:24 PM
