Results 1 to 10 of 13
Thread: WTB/PC: (NLA NOS) Bosch 007 2.2S Distributor
    Member clesch's Avatar
    Jun 2011
    Austria
    I sent my original distributor to a german specialist for a check and potential rebuild.
    He sent me a (pretty long) list of everything that’s wrong with it and offered me a completely new part for 1100€ ($1400).
    Apparently some messed around with it before and broke off pieces (tabs?) where the springs attach to. It’s also bent. (? — how can it be bent when it’s broken off? I don’t really get it myself, just trying to translate what he wrote me). He told me this piece is hardened and thus cannot be welded.
    Is that price for the NOS piece reasonable?
    If anyone has a 2.2S 007 distributor in good condition (doesn’t have to be NOS of course!) for sale, I would be very interested.
    Why not send it to another specialist? Or post a picture of what you need. I have some dizzy parts. BTW I think the 008 is the same dizzy but only has a different curve. Buying such a unit as a donor would even be cheaper than $1400.
    Richard
    Banned
    Nov 2004
    Scottsdale, AZ
    I believe I have an NOS one; priced at $1200. (Probably works out the same as your quote with shipping and duty.)
    BTW: "Only has a different curve" is no insignificant thing. There's a reason 006, 007, and 008 distributors have different curves.
    It's not significant thing in the context / the way it's written. When he uses the 008 as a donor he can rebuild the 007 dizzy to the curve that his engine needs.
    RIchard
    Feb 2007
    San Diego
    006 and 007 distributors have the same curve - the part number difference is for the rev limit on the rotor in the distributor. The E and S needs the same curve but the T cams come on at a different time so I do not think T dizy would work, at least that is what I have found by playing with different distributors in E and S engines.
    You should be able to get a good used 007 for much less than half the price quoted to you for NOS.
    Jun 2011
    Austria
    Thanks for all the input and pricepoints! I’ll definitely try to find a cheaper route than the NOS.
    Here are the pictures of the bent part he sent me. (don't ask me which one, I’m clueless )
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Here you go - not mine not affiliated no idea about the condition http://www.ebay.at/itm/280834931091
    Und in Deutschland ist ein NOS für 1200.- € http://www.ebay.at/itm/330698189542.
    Hast Du schon alle üblichen verdächtigen Händler abgeklappert?
    Grüsse
    Uli
    Nov 2003
    Santa Monica CA
    I recently bought a nice 2.2 S dizzy for $400.Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Jun 2011
    Austria
    Quote Originally Posted by uai View Post
    Grüsse
    Uli
    Der um 1200€ scheint genau exakt der zu sein, der mir um 1100€ angeboten wurde. Bei italienischen Teilen habe ich ein wenig bedenken, aber ich werde ihn um Detailfotos bitten. Abgeklappert habe ich bis jetzt Sportwagen Eckert, Freisinger und Mittelmotor. Leider erfolglos. Besten Dank!
    For the 2.2 E and S engines, the curves are both the same, just different rev limiters, which is a function of the rotor. So an E dizzy can be made into an S by changing only the rotor. Doesn't help if you need a concours # matching rotor, but find you an E and swap out the rotor.
    I know the 2.4S, 2.4E, and 2.4T (MFI) also have the same curves. Replace for what you need.
    Olin - Member #1375
    1972 911T
    Original
    Options added
  1. FS: NOS BOSCH distributor 0 231 159 002 JFDR6 in bosch box
    Last Post: 03-08-2013, 10:55 PM
  2. Replies: 2
    Last Post: 10-04-2012, 09:31 PM
  3. Help on value of 65-67 Bosch distributor
    By EA911 in forum General Info
    Last Post: 11-29-2011, 02:16 PM
  4. FS Bosch 2.0L Distributor
    By byron in forum For Sale: 911 Parts
    Last Post: 04-29-2011, 07:52 PM
  5. Bosch 2.0L Distributor
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 03-10-2010, 02:48 PM
