Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: search for 70T original engine pictures
    Jul 2010
    Bordeaux
    Thinking to a next engine restoration, I ask myself a lot of questions about the original look of my 70 T, I mean when he left the factory. I do a lot of research but can't find any pictures of it out and inside the car.
    So anybody got this kind of picture, colored one would be of course very helpful, thank you
    Jul 2010
    Bordeaux
    little bump... no one can help ?
    Is there anything specifically you're looking for in a picture? What I do is buy most any book that has pictures of original cars (not just restored ones) and usually between half a dozen books and the shop manual I can generally find a picture of an original car that will answer the question. I don't think there is any ONE book that will show it all. Some of the better books are by Brian Long, Brett Johnson, Tobias Aichele, and of course the factory shop manuals I mentioned. I hope this helps.
    Jul 2010
    Bordeaux
    Thank you ed, You're right I should be more precise, here are some of my questions
    1 - first is about original metal treatment of air box attachs, is it really dichromated (like many are on restored engine) ?
    2 - What are dichromated part of the engine ?
    3 - Wwhat is original color of air box, many I saw are glossed but, looking at mine I'd say it's satin black...
    4 - Where is originaly placed the fuel filter ?
    5 - Does the electric parts (on the left) are protected by a part like on 2.4l
    6 - Does the alternator fan (and around) is painted are not ?
    "70 T Engine
    First shot is very correct '69 engine installed in a stellar '69 T coupe. Then, More or less pretty original, not concours. Yellow Cad ("gold") hardware such as screws and some other parts has turned to silver as is does over time (sacrificial finish). And another, different "T" '70 engine. Oh ! You can almost forget the these two. Finally is the '69 Engine done by a concours expert friend of mine shown in the first shot. One will have trouble finding anything "wrong" with this one ! Note the not-yet-sacrificed yellow zink (or cad) Thanks.
    -Allen-
    Quote Originally Posted by qotsa View Post
    In addition to Allen's answer I'll look at my 71 tomorrow and see what I can determine from it as to the plating color. The air cleaner is a semi flat, NOT real shiny. There was no external fuel filter originally, only the filter in the tank. The relay board cover didn't start until 71, if your 3 fuse panel has a cover then it didn't get the big cover. The alternator housing strap was black.
    Matt Snyder
    Nov 2010
    Montclair, NJ
    Here is my 70T, I have cleaned the rust off on the bolts since photo was taken.
    Matt Snyder
    Early S # 1902
    Montclair, NJ
    68 911 Sunroof coupe polo red
    65 MB 23O sl light ivory 4 spd
    qutsa, I checked the air cleaner brackets on my 71, they are yellow, so I'm sure your 70 would be also. By that time most plating was yellow.
    this picture is from a 1 owner 29k mile 70T engine bay
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Here is a pic of my 71T motor with correct original Zenith carbs. Should be the same look as all of the 70T motors as well.
  1. WTB: Search for Blank 1972 Engine Case
    By porschersr73 in forum Wanted: 911 Parts
    Last Post: 07-29-2014, 05:12 PM
  2. Search for engine & transmission
    By Cliff in forum For Sale: 911 Parts
    Last Post: 10-04-2011, 01:45 PM
  3. Original engine/trans search
    By carsngolf in forum General Info
    Last Post: 08-20-2009, 06:14 PM
  4. engine search
    By raspy2point2 in forum General Info
    Last Post: 05-17-2009, 11:32 AM
  5. Help needed: 911T engine search
    By rs911t in forum For Sale: 911 Parts
    Last Post: 02-24-2008, 09:36 AM
