Thread: sway bar assembly
    Dec 2011
    Victorville CA
    sway bar assembly
    I am installing the factory 15mm rear sway bar on my 69 912. Where exactly do the consoles and ball pins get welded to the chasis and trailng arm? Does anyone have photos or a schematic so I can weld these for installation of bar, drop links and brackets for the rubber bushings.
    I did an install procedure here a year or so ago http://www.early911sregistry.org/for...ay-bar-install
    I think it explains it all well enough.
    Dec 2011
    Victorville CA
    Thanks. johnt gave it to me earlier this evening. Perfect. Great info. Anything new you want to add after a year?
    No, I can't think of anything I'd change. I will stress that I still believe it's very important to have everything clamped in place and check free movement before welding on.
    Dec 2011
    Victorville CA
    I wiil do it just like your thread.
  1. FS: 245 mm Fan Assembly 901.106.101.5R
    By Bert in forum For Sale: 911 Parts
    Last Post: 10-21-2013, 08:19 AM
  2. WTB: 245 mm Fan Assembly 901.106.101.5R
    Last Post: 09-19-2013, 10:33 AM
  3. FS: 18mm Front Sway Bar Assembly
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 01-20-2011, 02:23 PM
  4. H-4 light assembly
    By tfmcmahon in forum For Sale: 911 Parts
    Last Post: 07-17-2010, 05:33 AM
  5. Wanted: 15mm 1969-1973 911S front sway bar assembly
    By erick72pors in forum For Sale: 911 Parts
    Last Post: 11-29-2007, 06:13 PM
