Results 1 to 7 of 7
Thread: Coil Mounting Hardware
    I'm about to move my coil on my '68 S back to its' proper location on the electrical board, and I don't seem to have the correct hardware. What should I be using? Where can I obtain some. Thanks.
    Tyson
    Early 911S Registry #472
    1968 S - #477
    Mostly Stock
    Well, you need a 60mm Bosch Coil clamp. Don't get the one from the blue coil, it's too small, you want the original diameter. These are not particularly rare although they all have rust. I think they are the same size as the 6V coils as well if that helps.
    I have the coil clamp. I need to know what screws to use. I think there are speed nuts that go on the board. I'm just not sure.
    Tyson
    1968 S - #477
    Mostly Stock
    Yes, there are speed nuts(clip nuts) that slip onto the board, the screw is a about a 5mm sheet metal screw (from memory) and will have a 10 mm hex head.
    Thanks Ed. That's what I thought. Now to source those....
    1968 S - #477
    Mostly Stock
    Here is a shot of the board so you can see the speednut locations
    The little speednuts are form B 4,2
    The big speednuts are also form B, 6,3- unlike the little ones they don't show the size they just have a + sign
    These are cad plated and put on the board and the board painted black.
    The little screws are "hexagon head tapping screw 4,2"
    The big ones are "hexagon head tapping screw BZ 6,3 x 13"
    Your 68 uses a ceramic ballast resistor instead of the metal can and a hardi pump instead of a german bendix.
    Thanks for the help, guys. Coil mounted and I'm a happy camper now.
    Tyson
    1968 S - #477
    Mostly Stock
  1. FS: SWB Wiper Mounting Hardware
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 03-25-2013, 09:26 AM
  2. Coil mounting 2.0S 1968
    By Porsche-RSR in forum Technical Info
    Last Post: 03-07-2013, 11:08 AM
  3. W t b sun visor mounting hardware
    By gwilliams in forum For Sale: 911 Parts
    Last Post: 07-27-2012, 07:01 AM
  4. Fender Mounting Hardware Question
    By John912 in forum Technical Info
    Last Post: 06-30-2011, 08:42 AM
  5. Fender hardware mounting question
    By neilk in forum Technical Info
    Last Post: 01-30-2005, 06:11 PM
