Results 1 to 2 of 2
Thread: Replace this tank?
    Member clesch's Avatar
    Jun 2011
    Austria
    Replace this tank?
    I’m currently fixing the mechanics of my car and sent of the throttle bodies to Alan for a rebuild as well as the MFI pump to a local Bosch specialist.
    I used this opportunity to take care a tiny rust spot near the tank and decided to drain and remove the tank for this because I also have some accuracy issues with the fuel gauge sender.
    So held my phone into the sender hole and made a video of it!
    The (original) tank is clearly dirty. I wonder how much of it is rust and how much is other gunk that could be cleaned out.
    Or should I replace it out right away? Believe it or not, the car ran fine last year.
    Fuel filter will be replaced of course.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Looks like mostly varnish to me, if you are worried about it you can get it professionally cleaned.
  1. Replies: 4
    Last Post: 01-09-2013, 08:30 AM
  2. Radio Speaker Replace
    By John Straub in forum Technical Info
    Last Post: 05-25-2012, 08:31 AM
  3. Polish or Replace Windshield
    By FL-Frank in forum General Info
    Last Post: 08-17-2009, 01:28 PM
  4. Looking to replace batteries with dry cells
    By Perry911 in forum Technical Info
    Last Post: 06-03-2008, 02:02 PM
  5. How much work to replace floor pan?
    By asianbond in forum Technical Info
    Last Post: 12-15-2006, 09:36 AM
