Results 1 to 9 of 9
Thread: Help with engine stamp
    Posted in Pelican also
    Help. I'm thinking about buying a '72 T but the engine stamp looks funny to me. The numbers on my 930 are stamped on a portion of the case that appears to be cast. The numbers on this engine look almost to be on a machined "pad". I apologize for the crappy iphone pix. The numbers are 6120XXX, which checks out for a '72 T.
    The owner has owned the car for over 20 years so to think anyone would have restamped a T case would be unusual, but then again, I can't rule anything out. The engine has it's original MFI.
    Thanks in advance,
    Is there a type # stamped. gled
    Oct 2008
    Burford, ON, Canada
    http://www.early911sregistry.org/for...Engine-Build-s
    The thread above has great detail on the 2.0 engine #'s. The third # (build#) is not present on 1970 and newer engines.
    Other than the build #, the stampings are very much the same on the 1970 and later engines. Note that there are two locations for the engine serial # based on the aluminum and magnesium case designs. 914/6 is different again.
    Gled,
    I didn't notice a type #, doesn't mean it wasn't there.
    But looking at the examples in the other thread, the numbers are on the forward facing (rear of car) section of the case. The one I am looking at has it facing the right side of the car, (the machined pad in my photo).... very strange.
    Jan 2003
    NW Indiana
    I agree, the numbers don't look correct, especially the '3'. Can you get a clear photo of the serial number area?
    Brian
    '71T
    R Gruppe #299
    Unfortunately I didn't take any better pictures. I do remember the numbers not being stamped very deep.
    Jan 2011
    DFW TX
    The location is correct for a mag case, but the format seems odd. Should be stamped, not engraved. Could have been a replacement case with the number transfered??
    Here is another thread with an example:
    http://www.early911sregistry.org/for...ag+case+number
    So if it is a restamp, how would that affect resale when it came time to sell?
    If everything else looks okay I think maybe a mechanic transferred the number from the old case to the new case. Seen it a few times over the years.
  1. Date stamp madness
    By Frank Beck in forum General Info
    Last Post: 04-10-2016, 03:31 AM
  2. S caliper date stamp
    By geneulm in forum Technical Info
    Last Post: 07-15-2012, 03:22 AM
  3. Date Stamp
    By jetdriver21 in forum General Info
    Last Post: 11-15-2008, 07:57 PM
  4. Your Porsche on a Postage Stamp
    By GWN7 in forum For Sale: 911 Parts
    Last Post: 09-19-2008, 03:09 PM
  5. RS engine case stamp
    By 210bhp in forum General Info
    Last Post: 12-19-2005, 08:57 PM
