Thread: FIA/CSI Homologation document Nr. 503
    Feb 2007
    Cheshire, UK
    Does anyone have any information on (or even better a copy of) the FIA/CSI Homologation document Nr. 503 relating to the 911T?
    I am aware of document Nr. 577 dated 1/1/1968 and Nr. 607 dated 1/1/1969, however, I have not seen the earlier one. I got the number from some supporting documentation I recently received regarding my '68 car.
    Tim
    Early 911S Registry #1167
    Feb 2007
    Cheshire, UK
    I believe this will be dated 1/1/1966 and like the two later documents will be for Group 3 Grand Touring although I would expect it will be designated for "911" rather than "911T".
    Tim
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Tim
    Chris Seven posted information regarding FIA #503 here
    i have a lot of these but have not seen this one or form 183 that chris mentions
    this is also taken from the Appendix K regs
    "901/911
    - The 901/911 short wheelbase model introduced in 1963 is eligible as a GTS in Period F, to the
    specifications of the FIA homologation form n° 183 of 1965 only. (i.e. excluding subsequent extensions).
    Form n° 503 (Weber carburettors) is only valid for Period G.
    - Cars of Period F may use the camber adjustment facility featured on the front suspension top mounts,
    introduced on chassis n° 302695.
    - The use of the parts listed below is permitted (GTS, Period F, homologation form n° 183):
    - Fuchs 5½ inches alloy wheel.
    - Löbro half shafts.
    - The 901/20 type engine, and the corresponding rocker arms, may be used only in post-1966 911R.
    - Minilite wheels are not authorised for cars later than 1970.
    - 911 Carreras model G of the year 1974 and beyond may use 7 inches wheels at the front and 8 inches
    wheels at the rear, as supplied by the make concessionaire.
    - 915 gearboxes are not allowed on 911 cars before 1972.
    - 911 2.7 / 3.0 RS or RSR from 1974 onwards: the crankcases can be replaced by those for the 930 Turbo
    3.0 (cast numbers: 930 101 101 4R & 930 101 102 4R, or 930 101 103 4R & 930 101 104 4R), provided the
    cylinder capacity remains original."
    i am not sure how much it helps but does point to the observation that form 503 was about using Webers instead of Solexes
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  1. ST Homologation Documents
    By speedmoore in forum Technical Info
    Last Post: 12-25-2016, 05:11 AM
  2. 301259 Export Document 26.06.85
    By Carl Bauer in forum General Info
    Last Post: 04-07-2014, 11:05 AM
  3. Homologation for 1990 911 C4
    By spidersaurus in forum Other Porsche Passions
    Last Post: 08-13-2013, 07:46 AM
  4. Homologation for 1990 911 C4
    By spidersaurus in forum General Info
  5. Does anyone have a good "Bill of Sale" document?
    By endo911rs in forum General Info
    Last Post: 04-21-2011, 11:00 AM
