Thread: Oil Console Bolt Pattern
    Are all oil console fastener circle dimensions the same? More specifically; will a 70S console bolt to a 66 oil tank?
    50/50
    The bolt pattern and spacings are the same, the oil feed hole however is not. The break point is up to 68, then 69 and up.
    Thanks again Ed. By oil feed hole, do you mean the opening from the console to the tank?
    50/50
    Yes, that's the change. One is at the top, the other is at the bottom.
  1. Replies: 8
    Last Post: 02-10-2015, 09:23 AM
  2. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  3. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  4. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
  5. mounting pattern
    By GTS in forum Technical Info
    Last Post: 04-09-2009, 05:38 AM
