Thread: Front suspension pan measures
    Oct 2010
    Stockholm/Sweden
    Question Front suspension pan measures
    Hi there!
    Im in the process of fitting a new front suspension pan and front slam panel.
    Got a little bit confused after spotting this, can anyone explain? Could the diff. be explained by "upper" and "below" measures? Seems odd, or maybe I´ve just lost it?
    Both pics are from OEM manuals.
    Name:  Skärmavbild 2012-03-19 kl. 13.20.19.jpg
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Jan 2011
    DFW TX
    The number in parenthesis is called a reference dimension. It is redundant information and the toleranced dimension governs. Normally it would agree with the toleranced dimensioned however...
    Aug 2009
    edmond, OK
    Looks like the first drawing is looking from the bottom up.
    Second, top down from inside the frunk.
    Junior Member
    Nov 2012
    amsterdam
    1st drawing doesn't really make any sense since the other mesurement on same drawing shown inside the one you are refering to is a higher number yet should ofcourse always be les than the outher one :/
    Current aircooled classic cars:
    68 swb 911 2.0T targa
    69 lwb 911 2.0 T coupe (matching #'s)
    72 superbeetle
    Jan 2007
    Phoenix, AZ
    With a new pan you just need to worry about the 497 front to back dimension and then measure the opposite diagonal from the inside front control arm mount to the opposite rear. It should be 814.86 +/- 1.5. Those 2 measurements need to match left and right to be sure your are square. You also need everything to be level when measuring.
    Oct 2010
    Stockholm/Sweden
    I´m all done!
    To this
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
  1. 71T Front Suspension
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 09-20-2015, 12:00 PM
  2. WTB: NOS Front Suspension Pan
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 11-20-2013, 04:07 PM
  3. front suspension for 64-67 911 and 912
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-13-2012, 05:32 AM
  4. SWB luggage carpet set measures
    By jesseandersson in forum Technical Info
    Last Post: 07-04-2011, 01:01 AM
  5. Front Suspension
    By andrea70 in forum Technical Info
    Last Post: 09-22-2009, 05:50 PM
