Results 1 to 9 of 9
Thread: 1973 911 parking lights
    My 73 is an Italian car. When I pull the light switch to it's first position the headlights go on. I don't know if I have a problem with the switch or if this happens because it is a euro car and it is supposed to be that way. My U.S. cars are such that the first position on the pull switch is for parking and tailights and the second pull/position activates the headlights.
    Any assistance is appreciated.
    RGruppe member 445
    What happens when you pull the switch to the second position? Do the headlights stay on? I would start by removing the switch and checking all the connections against a wiring schematic.
    Ed- There is no difference between the first pull and the second one. The headlights stay on. I either have a worn switch, or this is how the switch functions for euro cars.
    Does anyone know is this is the way the switch was meant to work on euro cars?
    John.
    RGruppe member 445
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    My Italian RS has first pull for sidelights and second pull for headlights with the appropriate light appearing on the dash clock, one green and one blue if I recall correctly. Twisting the switch is for the instrument rheostat.
    Check to see if your parking light works right and left for the sidelights only using your turn signal lever.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    My French delivered 73S works just like Mike described above.
    Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Jan 2011
    DFW TX
    Also look at the fuse block to see if either the main beam wires are connected in the wrong terminal or if the main beam and parking light terminals have been jumpered to create this operation intentionally.
    Jul 2006
    Switzerland
    Quote Originally Posted by 210bhp View Post
    on mine (RoW swiss):
    -first pull: sidelights rear/front, instruments lights, green light IS on.
    -second pull: headlights plus all of above, green light is NOT on.
    -pull lever for long distance lights: long distance lights, plus all of above, blue light IS on.
    Registry member No.773
    A worn switch seems to be the problem. I found a good one on Ebay and will let you guys know the deal once I install it.
    RGruppe member 445
    The part number on my current headlight switch is 911.613.0129.00. I have found on Ebay what is claimed to be the replacement and the number is 911.613.029.03.This has raised some questions I have had a hard time finding answers to. If anyone can help, here they are: Is the new switch the correct or same part with a new part number?, and is my current euro headlight switch different than U.S. switches?
    RGruppe member 445
  1. FS: Reproduction 1970 & 1973 Le Mans Parking Pass Windshield Decal Sticker Ltd Run
    By rockandrollrods in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-01-2016, 08:29 AM
  2. Replies: 1
    Last Post: 01-21-2013, 07:58 PM
  3. 911R parking lights
    By typ901 in forum For Sale: 911 Parts
    Last Post: 12-26-2011, 04:43 PM
  4. How wire Cibie headlights with parking lights?
    By jameshtaylor in forum Technical Info
    Last Post: 07-13-2009, 05:23 AM
  5. 69-73 Front Turn Signals / Parking lights
    Last Post: 05-25-2009, 07:34 AM
