Results 1 to 9 of 9
Thread: WTB instrument light socket
    Aug 2005
    VA
    Failed VA inspection because the high beam indicator does not work :-( Turns out the light socket in the speedometer is bad (the part the bulb is inserted into) (tried fixing it but needs replaced). Can these be bought new? Or, does anyone have one they would like to sell?
    Many Thanks,
    Chris
    73 911 E
    Oct 2010
    South Carolina
    Stoddards has them for about 5 bucks with a spade connector on the back side. Just solder a female connector on the wire. Use a little dielectric grease on the bulb holder so it will come out easier. If you haven't replace all your bulbs as they get dim with age. Best wishes.
    Aug 2005
    VA
    Thanks bfunke. I will try Stoddard. Would much prefer a new one.
    Chris
    73 911 E
    Aug 2005
    VA
    Dangerous place that Stoddards ;-) Ended up spending a couple hundred on other stuff. They have all the details my car needs.
    Chris
    73 911 E
    Aug 2005
    VA
    yea he was a prick and I bring 4 cars to him a year.
    On the other hand I have been known to drive with my hi beams on by mistke :-/
    Chris,
    I should have an extra one lying around. It' yours for free if I can find one.
    Aug 2005
    VA
    Thanks for the offer Gruen911. I think I ordered the right one from Stoddard.
    Chris
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    which lights fit in here? ie size, watt? can they only be ordered at stoddard, or can i find em at my local autoparts store? I have a few different ones i need to get for gauges.
    Harry Hoffman
    356 Registry Member #36691
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    harry they are 12 volt 2 watt bayonet style, osram spec 3898, stoddard part 90063110290
    registry #2072
  1. 1968 911S Instrument Set
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-03-2012, 02:19 PM
  2. Instrument Glass Cleaning.
    By Chris Banks in forum Technical Info
    Last Post: 11-05-2011, 12:02 AM
  3. WTB: driving light bulb socket
    By JHunter in forum For Sale: 911 Parts
    Last Post: 08-19-2007, 04:07 PM
  4. Blaupunkt Aux Socket
    By johntyboy in forum Technical Info
    Last Post: 02-05-2007, 04:34 PM
  5. Instrument einsteins pls
    By gulf908 in forum General Info
    Last Post: 08-26-2006, 02:22 AM
