Thread: Hi beam indicator on 73 E
    Aug 2005
    VA
    Can someone post a pic or tell me where the hi beam indicator connects. I believe it is one of the connections on the main light switch but am not sure. My wire from the tach goes nowhere (probably explains why it's not working :-/).
    Many Thanks!
    Chris
    73 911 E
    Feb 2011
    Surrey, UK
    From the wiring diagram it connects to fuse 1 of the 8 pole fusebox (it uses the same connector and side as a single white wire) There is no wire connected on the other side as fuses 1 & 2 are connected in the fuse array, and the white wire connected to the other side of fuse 2 provides the live supply from the light relay.
    Hope this helps
    Mick
    Aug 2005
    VA
    Thanks Mick,
    Was hoping it woruld be easier then that but did it yesterday exactly as you described and works perfectly.
    Chris
    73 911 E
  1. FS: a few tail indicator lenses and one front indicator lens
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 04-09-2014, 08:32 AM
  2. 2.0 Litre H-beam Rods
    Last Post: 02-25-2011, 12:33 PM
  3. H Beam Rods
    Last Post: 12-16-2010, 06:17 AM
  4. H1 Looking Sealed Beam Components
    Last Post: 03-29-2010, 12:17 PM
  5. H1 both bulbs on with main beam...
    By mjmoran in forum Technical Info
    Last Post: 12-01-2004, 08:55 AM
