Thread: WTB - Used Koni Front Strut Insert 82R 1308
    Looking to buy a few 82R 1308 Koni Front Strut Inserts. These are for the SWB Koni only front strut.
    Thanks and best regards,
    Brad
    949 266 4205
    brad at nextmill.net
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Dec 2011
    Victorville CA
    I'll send PM with pictures. I have one but it's off my 69. I'll send pictures anyway.
    After re-reading I think you need the shocks not struts.
    Aug 2007
    Phila Pa. area
    Inserts
    Brad
    I have two NOS Koni inserts 82R-1647 they are Koni inserts for Boge Struts 1969 to 74 I think . Probably not what you want.
    Mike Curnow
    Mike
    Hi Mike and Bob,
    Thanks for checking on this. The inserts I am looking for are for the 65-68 911 Koni only front strut housing. This is the orange housing with the taper at the bottom of the tube. The 82R 1308 strut inserts have a slight taper at the bottom as well.
    Thanks again,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Feb 2003
    Corpus Christi, Texas
    The current version of that insert is available. 86-1308. That may not be want you want to do but if all else fails.....
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
  1. Date codes on koni strut insert
    By TPC in forum Technical Info
    Last Post: 02-15-2014, 04:06 AM
  2. Replies: 2
    Last Post: 08-11-2013, 11:43 AM
  3. FS: NOS Koni Front Strut Insert
    By Brad Davis in forum For Sale: 911 Parts
    Last Post: 08-19-2012, 07:25 PM
  4. KONI Strut Housing and Insert Don't Fit????
    By bobmagyar in forum Technical Info
    Last Post: 03-16-2006, 05:29 PM
  5. Koni Strut Insert tool
    By quattro in forum Technical Info
    Last Post: 03-26-2005, 12:09 PM
